Results 1 to 6 of 6
Thread: 355 check suspension light
    Mar 2007
    Bournemouth
    David
    21
    Default 355 check suspension light
    Had the check suspension light come on in the car recently. It seems to stay on when I start the car sometimes, no matter how long I leave the ignition on before strting the car I can then drive the car around for a while, switch the engine in and off a couple of times and the light will go out. Other times it will not come on at all.
    Anyone else experienced this and is there a common reason for the light coming on?
    David.
    ric355's Avatar
    ric355 is offline Nowhere to put the shopping -The Ferrari F40 Club Member
    Richard
    3,438
    http://www.the355.com/mambo/showwork...e=101&volume=2
    Read the "System operation" section. A few pages in there are several remarks about possible causes of the light coming on - actuators, speed signal etc.
    Aug 2006
    Alabama
    348 Primer
    44
    Is your stereo/amp on or off when the suspension light illuminates?
    Mar 2007
    Bournemouth
    David
    21
    Quote Originally Posted by no doubt View Post
    Always on.
    David.
    Aug 2006
    Alabama
    348 Primer
    44
    Usually that light is from a broken electric shock actuator (very similar part to that used on Corvettes). If your speedometer isn't working, however, that too will trigger that light.
    ...but some super-loud-bass stereos might trigger the light as well, so no harm in at least turning OFF the stereo (not just volume down) to see if the light goes out correspondingly (give or take 20 seconds).
    Jun 2006
    Eastbourne
    Lawrence Mason
    37
    Have had this, started by light coming on intermittently then became permanent. Was suspension actuator. Has to go to Ferrari Dealer or specialist as they need to plug car into their computer to show which actuator has failed. Kent High Performance did this for me, part was 250 approx and with labour etc cost around 550.
    Hope though it is just something simple
  1. 355 3rd Brake Light
    By LazyLobster in forum Technical Q & A
    Last Post: 15-04-2007, 09:45 PM
  2. Is the 355 steering very light
    By minter in forum Ferrari Talk
    Last Post: 19-03-2007, 05:21 PM
  3. Replies: 32
    Last Post: 15-12-2006, 08:07 AM
  4. Intermittant slow down light on my 355
    By STUEE in forum Technical Q & A
    Last Post: 04-07-2006, 11:12 PM
  5. 355 Brake warning light
    By spidermanUK in forum Technical Q & A
    Last Post: 07-11-2005, 05:32 PM
