Results 1 to 1 of 1
Thread: 308 GTS QV Birdman fuse box upgrade
    Oct 2007
    Roquebrune Cap Martin
    Roland
    13
    Default 308 GTS QV Birdman fuse box upgrade
    Just installed the "Birdman fuse blocks" into my 1983 euro 308 GTS QV
    lots of threads on these over on the "dark side", so purchased a set
    What a difference it has made and very easy to install
    to Install I:
    disconnected the battery on the ground connecter under the bonnet; Then marked the connectors with a marker pen;
    Then transfered the upper connectors to the top side of the birdman blocks;
    Unscrewed the old fuse blocks and let them hang on the lower connectors;
    Screwed in the Birdman blocks and then transfered the lower connectors. The correct fuses were a bit hard to find overhere but our 30mm glass fuse versions fit and work well (same diameter just 2mm shorter).
    Now the speedo doesn't wobble around and cut in and out!
    I can see the instruments at night!
    The windows work faster!
    The headlights have gone from a candle yellow glow to something approaching white light! (cibie and relay upgrade soon)
    pic of installation for the record.
  1. 308 GTS roof panel.
    By timtom in forum Technical Q & A
    Last Post: 14-07-2008, 07:56 PM
  2. 308 GTS QV Birdman fuse box upgrade
    By rolster in forum Technical Q & A
    Last Post: 30-11-2007, 02:16 PM
  3. 308 gts purchase
    By Malh001 in forum Ferrari Talk
    Last Post: 01-07-2007, 02:54 PM
  4. 355 Fuse box
    By matkat in forum Technical Q & A
    Last Post: 10-12-2006, 06:51 PM
  5. Testarossa fuse box
    By yellow jacket in forum Technical Q & A
    Last Post: 12-07-2006, 07:54 AM
