Results 1 to 9 of 9
Thread: Re-attaching resin shields
    Aug 2006
    Hamilton and NYC
    Greig M
    78
    Default Re-attaching resin shields
    I've recently had to remove one of my resin shields (360) as I was getting a minor bit of paintwork done due to a badly repaired stonechip (started to rust underneath). It came off easy enough and is in good condition - can it be reattached? If so what kind of glue should I use?
    I was thinking of going for yoshi's shields, but the wesbite seems to indicate they are $350 each (i.e. $700) - am I reading this correctly, or is it 350 for a pair? At $700 the reports of suspect workmanship,durability and service are putting me off.
    If all else fails, I'll go get a new set of resin shields from the dealer - anyone know how much these cost?
    Earth
    19,733
    Quote Originally Posted by GreigM View Post
    Not worth trying to refit the Resin ones, buy new from Ferrari UK, cost is about 3.00 each
    Jun 2007
    Nr Glasgow
    Zak
    825
    Resin shields from yoshi are nowhere near as expensive as you said. You can get lovely enamel shields for 260.00 (Includes Postage) from "wingbadges" on eBay. They are based in Sweden and do the Best non OEM shields for Ferrari.
    candellara's Avatar
    candellara is offline You thought the Enzo was ugly? - The Ferrari FXX Club Member
    Jun 2006
    South East UK / Hamburg
    Candellara
    6,306
    $350 is for a pair from Yoshi
    Aug 2006
    Hamilton and NYC
    Greig M
    78
    thanks guys, never realised the resin ones were so cheap - just assumed everything from the dealer was a minimum of 50 quid ;)
    Thanks for clarifying yoshi's shield - just got confused when the ordering page on the site said:
    Scuderia Fender Shield (Type-A)
    and showed a picture of a single shield........
    May try the yoshi shields as I have an address in the US so can get them next time I'm over...
    Murph7355's Avatar
    Here there and everywhere
    Murph
    14,313
    Yoshi's items look great on the car.
    And you were right about Ferrari tat being overpriced. At 3 quid the resin shields are about 50 quid overpriced
    Fraccie's Avatar
    Dilligaf
    Ade
    25,945
    Quote Originally Posted by Murph7355 View Post
    Utter crap................nice to see you back Mr Grumpy.....
    Nov 2007
    Berkshire
    George
    55
    Can someone retrofit the OEM ones with the recess as when ordered from factory so they look as they should from Ferrari or as a retrofit they can only be glued ( resin or metal) to the side wing ? If so is that easy job and who is good for this apart from a main dealer ?
    Murph7355's Avatar
    Murph
    14,313
    Quote Originally Posted by Fraccie View Post
    You are correct. The resin shields are as you describe.
    And thank you ;)
  1. 348 Carbon Fiber Exhaust Shields
    By Lars348 in forum Ferrari Talk
    Last Post: 19-11-2007, 09:25 PM
  2. Yoshi wing shield badges
    By New to this in forum Ferrari Talk
    Last Post: 05-11-2007, 07:11 PM
  3. Spare shields
    By Fraccie in forum Lounge
    Last Post: 09-06-2007, 12:40 AM
  4. Removing resin wingshields
    By candellara in forum Technical Q & A
    Last Post: 06-05-2007, 03:34 PM
