Results 1 to 5 of 5
Thread: 348 / 355 Carpet
    Chichester
    Dunx
    670
    Default 348 / 355 Carpet
    Does anyone know if a 355 carpet will fit a 348?
    I know basically they are the same car but I wan't to change my blue carpet for a black set from a LHD 355 TS. Will this fit a LHD 348 TB? I'm concerned about the it around the back of the centre console, I thinking there is a difference between a TS and a TB. Can anyone confirm?
    Mar 2008
    Malta - at the pub mostly
    Xmun
    2,513
    Quote Originally Posted by Littleblackflash View Post
    I'm sure the centre console part is different, because the F355 is a full carpet and the 348 is cut
    Chichester
    Dunx
    670
    so does that mean a 355 carpet would fit a 348 but not the other way round.??
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,917
    Dunx, not sure if this picture helps but you can see how a 355 is split along the centre and only attached across the rear portion.
    BTW, my carpet was a replacement and from what I can tell was trimmed to fit. i.e. the spare was not a direct fit to the car.
    From the 348 parts catalogue, it looks like two PNs are listed (pilot, item 5 and pax item 4) but the 355 has just one PN (item 3).
    The uncut portion at the rear centre of the 355 carpet may be to allow for a GTS where the centre consul does not touch the rear bulkhead leaving a gap for the roof to sit. In a berlinetta, the centre consul is a tight fit against the rear bulkhead thereby covering all the carpet in the centre.
    From the 348 pictures, it looks like the rear bulkhead carpet has a longer leg at the bottom which extends towards the front of the car thereby covering any joint in the base carpet at the centre. Perhaps that is where the difference lies.
    Sorry, not an answer but perhaps food for thought.
    Chichester
    Dunx
    670
    Thanks Terry. I think that answers my question. Having a TB the whole middle bit would be covered. I was concerned about the triangle things that hold the roof in on a TS but from the pics it looks like they fix to the rear seat bit.
    I'm removing the roll cage in my car and need a new carpet to cover the holes. A LHD carpet is hard to find in black, Tan is quite common.
  1. Club Scuderia Owners Club!
    By Gimme Fuel in forum Ferrari Talk
    Last Post: 18-07-2012, 12:09 AM
  2. Now an ex-Ferrari owner
    By Bronco Jr in forum Ferrari Talk
    Last Post: 05-07-2008, 03:07 PM
  3. 1993 Ferrari 355 - really a 348!
    By r2d2 in forum Ferrari Talk
    Last Post: 08-08-2006, 09:18 PM
  4. One for Sy, 355 doors on 348
    By LazyLobster in forum Ferrari Talk
    Last Post: 23-01-2006, 04:45 PM
