Results 1 to 10 of 29
Thread: 355 2.7 won't start, help please
    Mar 2010
    Marco
    683
    Default 355 2.7 won't start, help please
    Hi all, in something that is freakishly reminiscent of my summer problems, my 355 refused to start this evening when wanting to return home from a friend's house. I am currently on a horrible train home so thought I'd do something useful and see if anyone can help....
    When switching the ignition on, the Amber and red lights for the 1-4 bank illuminate and stay on. When I attempt to start the car, the engine turns over, the red light switches off, the Amber stays on. No bank catches and there is no unburnt fuel coming out of the exhaust.
    Possible relevant other info:
    1) In the summer, an almost identical problem (minus the red light which never came on) was diagnosed as a badly connected after Market immobiliser which was not releasing one of the fuel pumps. Immobiliser guy "fixed" this when I got back to blighty saying he had now (possibly, if memory serves) switched the original fuel pump immobiliser channel to an engine ecu instead.
    2) over v bumpy roads while driving today, the 1-4 Amber light did come on, but when I stopped the car, turned ignition off and restarted, the light disappeared
    3) the other weekend I changed the 1-4 coil pack myself, I had a fiddle tonight and nothing seemed to be loose with it or anything
    Plan is to head back to my mate's house tomorrow morning and try and effect a repair myself If possible with advice from here. Failing that, I will have te car taken to somewhere like autofficina if they are open on a Sunday
    Any help suggestions much appreciated!
    ronrob is online now Rear lights like a farm gate - The Ferrari 348 Club Member
    866
    Bad luck. We can suppose that you have checked all the fuses?
    Jun 2009
    The Dark Side of the Moon
    Neil
    911
    Hi Marco, sorry to hear you are having trouble again.
    Could it be the after Market immobiliser again? I'm not sure how you would disconnect an immobiliser fuel cut and then connect it to the ECU unless he has interrupted a feed to the ECU. Do you know where he made the connections and disconnections?
    Mar 2010
    Marco
    683
    Nope, I haven't, my fingers were freezing off and I needed to get home so didn't have time! Fuses are in the footwell and in the boot if memory serves right? I can have a look at them tomorrow when I go back
    Mar 2010
    Marco
    683
    Quote Originally Posted by Bueller View Post
    Unfortunately I do not I managed to wiggle some of the immobiliser wires after getting into the footwell in case any connection may have come loose or something, but couldn't really see anything as the head torch I had on was not great and the immobiliser itself was inaccessible without removing more of the interior trim which by that stage I could not be bothered to do
    866
    Meant to say fuses AND relays. As you know if it's the immobiliser that's a lot more tricky. Spraying aerostart (engine starter fluid) for a few seconds into the air intake would show if it is a fuel issue (for whatever reason).
    Good luck!
    Mar 2010
    Marco
    683
    Good luck!
    Silly question, but how will this show if it's a fuel issue? Will the engine catch briefly?
    866
    Quote Originally Posted by Mario149 View Post
    Not a silly question. Yup, a can of the stuff is pretty useful. A few seconds into the air intake is a sure fire (!) way to tell if the non start is due to no fuel. You've got it. If the engine fires up you've got a fuel problem; if not, it's electrics. (Well it's true most of the time). You can get a can in Halfords. Lorry drivers use it to start cold, reluctant diesels!
    Jun 2009
    Neil
    911
    Do the easier things first as ronrob listed, then move onto the immobiliser.
    If you can, test all the fuses with a tester, I've seen people check them by eye and not noticed they are blown.
    Mar 2010
    Marco
    683
    Will do, I'll take a multimeter with me I'm praying it's just a fuse, I can't be bothered to have loads of hassle today, I've just been knocked sideways by the flu over night
  1. 355 Battery Drain / Charging Issue
    By Arron in forum Technical Q & A
    Last Post: 04-01-2011, 07:58 PM
  2. FERRARI 355 SPYDER OR 360 SPYDER HELP
    By Paul1 in forum Ferrari Talk
    Last Post: 04-02-2009, 02:24 PM
  3. Will the Speedo from a 2.7 355 work in a 5.2?
    By cactussed in forum Technical Q & A
    Last Post: 30-09-2008, 05:24 PM
  4. Ravi 355 - 1997 F355 GTB
    By Club Scuderia in forum Buyers Guides, Restorations and Running Reports
    Last Post: 02-03-2006, 08:03 PM
