Results 1 to 1 of 1
Thread: Wheel torque data
    Malcolm W
    625
    Default Wheel torque data
    I have had quite a lot of owners asking what the correct wheel torque is for their Ferrari's. Even if you don't remove the wheels yourself it's worth knowing and passing on to whoever is re-fitting your wheels (could be just a tyre shop).
    Always clean the wheel bolts before re-using, but do not lubricate the contact surfaces between the wheel bolts and the wheel rim and also between the wheel rim and brake disc.
    Ideally after torquing the wheel bolts the car should be driven for a couple of miles and then re-checked.
    I have listed in lbft (pound foot)
    308GT4....................65
    308/328...................72
    MON8/QV.................72
    348.........................72
    Mt...........................72
    F40.........................470
    400i.........................72
    TR (single nut)...........325
    T/R,512,F512M...........72
    456..........................72
    355..........................72
    360..........................74
    550/575....................74
    F50..........................502
    430.........................74
    612...........................74
  1. 430 wheel nut torque setting?
    By kryten22uk in forum Technical Q & A
    Last Post: 06-04-2009, 02:22 PM
  2. CS wheel bolt torque settings?
    By jo5eph in forum Technical Q & A
    Last Post: 26-11-2008, 10:30 PM
  3. 360 wheel bolt torque
    By T-bone360 in forum Technical Q & A
    Last Post: 19-03-2008, 04:43 PM
  4. Stradale Wheel Torque Settings
    By MARKY 355 in forum Technical Q & A
    Last Post: 24-04-2007, 06:32 AM
  5. wheel torque settings
    By dazza1966 in forum Technical Q & A
    Last Post: 14-09-2006, 08:06 PM
