Results 1 to 10 of 14
Thread: 348 won't start
    Jun 2007
    Rickmansworth
    Trevor Skedge
    348
    Default 348 won't start
    Not used the 348 for a month but the battery has plenty of charge however when I went to it this evening it wouldn't turn over. Central locking works with enthusiasm and ignition lights are bright but when the key is turned, nothing, no dimming of ignition lights. No click at all. I'll have a look tomorrow but thought I would ask first for pointers. Was fine when I left it.
    Trevor.
    Angelis's Avatar
    London/Essex
    Sy
    17,009
    Security immobiliser?
    3,359
    Charge your battery for an hour or so then try it again. As a guess you may have the have start problem which can be cured with a Bosch WR1 kit. My symptoms were now and again there wasn't even so much as a click out of the starter motor but all other electrics worked fine. Charging the battery for a while then retrying would have everything back to normal. My car starts much better after fitting one.
    I paid 40 delivered from US for an "official" one but TBH you can make one yourself for about a tenner. Its just a relay and a 30amp fuse.
    http://www.clubscuderia.co.uk/forum/showthread.php?45388-348-DIY-quot-Restoration-quot&p=747316#post747316
    Fitting is easy and totally eversible...
    http://www.clubscuderia.co.uk/forum/showthread.php?45388-348-DIY-quot-Restoration-quot&p=749800#post749800
    NB If your battery is getting on it may be worth fitting a new one too.
    Jun 2007
    Rickmansworth
    Trevor Skedge
    348
    I'll give it a go but I did put a start pack on the connections in the engine bay but still nothing. If I can find the starter fuse I'll try that first.
    Trevor.
    Jun 2007
    Rickmansworth
    Trevor Skedge
    348
    Charged the battery over night but still no joy so will look at the connections mentioned under the air box first tomorrow and the the power supply to the solenoid. Thanks for the links and I'll fit a relay too.
    Trevor.
    3,359
    Jun 2007
    Rickmansworth
    Trevor Skedge
    348
    Thanks all for your advice. Had a think about it and ran a lead from the solenoid to the positive bus on the inner rear wing and she fired straight up. Started and stopped fine after that but proves its supply to the starter solenoid and a start relay would be the cure and of course clean of various connections now I can get the car home.
    Trevor.
    3,359
    My feeble attempt at some instructions - hope they are of some help! LOL
    http://www.ferrari348manual.com/t16-...lay-fitting#21
    Jun 2007
    Rickmansworth
    Trevor Skedge
    348
    Thanks again all very usefull. I'll start a new thread soon when I can't cure my heater panel problems :-)
    Trevor.
    Nov 2009
    Cambridgeshire
    Greg
    572
    I got mine out of storage on Friday, where its been sat for about 5 months connected to an Accumate. I had to hold the key in the 'crank' position for approx 5-7 seconds before the started would engage...
    I have had this before and basically the longer the car is left unused, the longer you have to hold the key turned to start it! If you leave it for a week, there is only a small delay until the starter kicks in... Its also worth me mentioning that i have a brand new ignition switch fitted to my car, so it cant be that that causes the issue.
    Its never really bothered me to be honest, as it always starts.
  1. 348 won't start...
    By Mike#10 in forum Technical Q & A
    Last Post: 09-02-2013, 11:13 PM
  2. 355 2.7 won't start, help please
    By Mario149 in forum Technical Q & A
    Last Post: 01-02-2011, 02:12 PM
  3. 348 car won't start help!!!
    By Chris honeywell in forum Technical Q & A
    Last Post: 15-09-2009, 08:38 AM
  4. HELP - 360 won't start !
    By stimo in forum Technical Q & A
    Last Post: 25-12-2006, 09:43 PM
  5. Replies: 16
    Last Post: 11-12-2006, 12:52 PM
