Page 1 of 11 123 ... LastLast
Results 1 to 10 of 104
Thread: RD250LC Project
    3,548
    Default RD250LC Project
    Moving from the previous thread. I'll keep posting whilst there are people interested.......
    The story so far.....
    I wanted a bit of a project for my 50th birthday and have been looking at bikes from my youth for quite a while. One of my childhood best mates has a bit of a collection of 1980's two strokes including several 250 LC's, a mint X7, lots of air cooled RD400's and 250's.
    My wife was asking what I wanted I said I wouldn't mind a 350LC if I could find a decent one in the right condition, hence my first post. She went to see my mate who said he would look for one for her/me. After a couple of weeks I suggested a 250 could be better value and my mate then offered Clare this bike. So rather than me find it, it found me.......
    The bike is showing 15,300 miles, is SORNed and still has a 2004 tax disc on it. It was last MOT'd in 2006 and gained only a handful of miles since that MOT. A DVLA search shows no other MOT history. My mate bought it in 2007 and has never ridden it. It has 7 previous owners though.
    Apart from the V5 there is no other paperwork with it, so if it were a Ferrari it would be worth about 2.50 Incidentally it was registered in 1987 on an E plate whilst they were only made realistically between 1980 and 83. Most of the plastic mouldings are dated circa 1980 so this bike was obviously a victim of the learner laws which killed demand for 250's in the mid-80's and consigned it to it's first few years in a crate.
    I pretty much spent the next week pulling it to pieces, inspecting, cataloguing and boxing all of the bits.
    It shows a lot of good signs that the mileage is about right. Very few of the fasteners have been undone (shown by the corrosion free areas underneath), it has the original sprockets (apparently valuable to a concours builder) and I'm pretty certain the heads haven't been off so I'm expecting it to be on standard bores (we'll see later on).
    There are also no signs whatsoever of it being dropped or bent which is good.
    Anyone who knows these bikes will know corrosion is an issue. The paint is tissue paper thin and a single winter of salt roads would reduce one to a heap of rust. This bike looks to have seen a few winters then left in storage.
    This is typical of the frame underneath the clothes.......
    The finished standard I'm looking at is as 'showroom' as possible but not concours hence the easy decision to powder coat the frame. All of the frame components, subframe, engine mounts and brackets are at the powder coaters being finished in gloss black. I'm refinishing the bars and upper yoke in satin black (if they have read my instructions . I will find out Thursday).
    One of the features of these bikes is the green drab finish of many of the metal components and hardware. See the bottom yoke above. Where possible and even if there is slight corrosion I'm retaining this without refinishing. The kick start and rear brake are good examples.....
    The alloy fork legs and foot rest mounts are surface corroded and I'm not sure what to do with these yet. I need to see a standard bike to decide. I will probably polish and then brush. The powder coater said you cannot apply clear over polished alloy as it yellows...True?
    The one issue I have is the main stand retaining pin was corroded in place. I had to cut it in 4 places to remove the stand. A new one is 147 or I can try to get it out. Any ideas? The powder coater guy tried Oxy/Acetylene on it and it still wouldn't budge. I'm not sure I'm ready to give up yet as I've forked out 500 today for a gearbox repair on the kids car
    Name:  IMG_0450 (600x800).jpg
    Pretty much all of the zinc plate that is exposed is also shot. Here it is laid out....
    I've decided to use a local company in Crewe who come recommended via some bike forums. Turnaround is about a week and total cost is about 70 for all of the parts and fixings. I also managed to replace some off eBay with better quality parts. I'm going for BZP on all of these bits.
    Next is the tin ware. The tank is very good both inside and out. You can get them repainted as a set for about 350 -500 depending on how much work the tank needs. The metal is wafer thin so internal corrosion from water in the fuel is a big issue if they have been stood without oil in the tank.
    The panels on this bike are really good and original. I will definitely not be doing anything to these unless I find an issue later e.g a pin hole.
    Name:  IMG_0291.JPG (2) (800x521).jpg
    Finally for tonight the motor is out but untouched. The oil was a bit mucky but still OK. Remember the crankcase is lubricated via the two stroke injection. The coolant was exceptionally clean........
    I need to repaint the barrels and whilst they are off I'll check the bores and if nothing else, change the rings and little ends.
    Name:  IMG_0284 (800x600).jpg
    Name:  IMG_0286 (800x600).jpg
    Next job is collect all of the bits back together from the painters and platers and then order what I'm missing/replacing.....
    Nov 2007
    sarf eest lundun
    steve
    986
    A nice little project you got there, nothing like the smell of a two stroke and the sound of micron pipes. http://www.youtube.com/watch?v=Rq7UEbgOKp8
    3,548
    Quote Originally Posted by darft vader View Post
    Is that yours? Just watched the video...
    I've picked all of the frame parts up from the powder coasters this morning. Very pleased with the end results.
    I had the bars and top toke done on satin.
    All of the threads have been plugged but I'll run a tap through them tonight.
    The BZP stuff is due back on Saturday.
    I managed to get one pin out of the stand but we got a bit overconfident and damaged the stand getting the other one out. I'm now in the market for a new one.
    I really must sit down and order the parts need otherwise it will grind to a halt!
    Nov 2007
    sarf eest lundun
    steve
    986
    Sorry, the bikes are'nt mine just a nostalgic vid. I had a few mates with rd's and always liked them, you could always here them coming from miles away back in the day. The bike seems to be making good progress in time for the summer.
    Kent
    293
    Love these will watch with interest.
    3,548
    Default Not much progress this weekend
    With Mother's Day duties and refitting the gearbox into the kids car I've not had much me time this weekend.
    I've just ran a tap through the threads in the frame and trial fitted all of the bolts and brackets.
    It's the first time I've used an electroplater so it was a bit of a learning exercise for me. Most of the bits came out great. A couple of items I should have polished them before the process as the pitting shows through. Overall though, very pleased with the results.
    I've just had one of the carbs apart and again it looked like it had never been stripped. I've got it in the USB now so I'll post pics later......
    3,548
    The carbs needed a good clean inside and out.
    No real issues and the needle set at the factory position of 4th notch.
    Only part required is a new O ring for the float valve body. As a repair kit is about a tenner and most of it isn't needed I'll just source a couple of rings.
    A hour or so in the USB cleans everything up nicely
    Good to see not only me used to tap the bowl with a screwdriver when the float was stuck! Animals!
    3,548
    The wheels are going to be a labour of love!
    The rear is fine as it was covered in chain lube which has protected it.
    The front has been attacked by brake dust as the disc side Is clearly worse.
    The paper thin black paint is dull and you can see the alloy coming through. If you scrub too hard it will flake.
    The alloy parts are bare alloy so will polish up Mother's mag polish but I'm undecided whether to repaint as they are not the standard I'm looking for.......I may look for another set to refurb.
    Any suggestions? Painting will mean front and rear and be a real ball ache......
    Out of interest, does anyone know what the JWL logo is? I see this on a lot of wheels including Ferrari ones....
    For tonight I cleaned the inside even though it won't show!
    New tyres and tubes are on the way...
    3,548
    Tyres turned up yesterday along with other shiny new bits. My genuine yam delivery hasn't showed up yet which is a bit worrying....I'll keep an eye on eBay!
    The tyres were a tip from a mate. Dunlop K82 tubed tyres which have the classic TT100 tread pattern. Not that I'd remember what it looks like...
    The first tyres that were used to lap the island at 100MPH
    3,548
    Progress tonight has been good as the wife was out and I was home alone.
    New 1/4" ball bearings in the head races. 19 in each.
    I did consider taper rollers but I like to keep things standard.
    Tightened them up to take out the play and they feel great.
    http://img.tapatalk.com/d/14/04/04/nuqymava.jpg
    After that I thought I'd put the loom back in.....
    But got carried away and put half the bike back together!
    Still need to press the new swing arm bushes and fit the swinger but I need a couple of thrust caps that must be in a previous owners coffee jar of spare bits....
  1. The Project car
    By Trackdaydude in forum Ferrari Talk
    Last Post: 18-12-2013, 03:43 PM
  2. project 355
    Last Post: 11-12-2009, 11:57 PM
  3. Project - TR
    By AmoCS in forum Ferrari Talk
    Last Post: 19-09-2006, 08:32 PM
