Page 74 of 74 FirstFirst ... 24 64 72 73 74
Results 731 to 737 of 737
Thread: F430 New owner diary inc. maintenance & upgrades
  1. #731
    MWStewart is offline I have a dodgy moustache - the Ferrari 308 Club Member
    663
    Thanks Chris. It's certainly added to the overall package.
  2. #732
    663
    As phase two of the project is drawing to a close I've had a checkpoint to see what's left to exactly match the Scuderia specification.
    In scope, and in likely order of execution:
    1) Engine management - many changes;
    2) Suspension flamblocs (inboard, low deflection swivel joint/isolators) - increased shore hardness;
    3) Rear under tray - lighter, made of a composite material;
    4) Rear bumper grille;
    5) Carbon door cards - lighter. I already have these;
    6) Steering rack - 15:1 vs 16:1;
    7) Steering pump - valved for less assistance;
    8) Engine oil 'disareator' (combined dry sump reservoir and breather tank) - redesigned to cope with higher levels of blow by and the demands of track driving.
    Out of scope:
    1) Engine oil and water pump - will come as part of the planned large capacity engine build in phase 3;
    2) Removal of carpets and sound deadening - I don't want to do this because the weight gain is quite minimal but the effect on cabin noise is significant.
    More to come...
  3. #733
    663
    Scuderia Engine Management Conversion
    I will cover off the main differences to the F430 management. Both cars use the same ME7.1.1 engine ECUs but with different input/output assignments.
    MAF sensors and engine control strategy
    The F430 uses the Bosch HFM5 and the Scuderia (and 458 on) use the HFM7:
    "Except from the new sensor design, the air flow meter used on F136ED (Scuderia) engines is characterised by the absence of an air flow strainer. The task of an air flow strainer is to ensure a regular and laminar air flow inside the sensor duct. At the same time the strainer also forms an obstruction to the incoming air flow. By eliminating the strainer, a power advantage of 7-8 hp is obtained thanks to a more free air flow.
    The absence of the strainer will cause turbulences in the sensor duct which translates into an unreliable mass air flow signal. For this reason the mass air flow is no longer the main parameter to calculate the injection quantity, but will only be used to apply corrections on the fuel quantity. Instead, throttle position and engine speed are used as main parameters. This modification implicates a specific calibration of the engine control software."
    Ion-sensing
    The Scuderia does away with the two knock sensors per bank that the F430 uses and instead uses ion sensing technology to adjust ignition based on cylinder conditions that preceed knock, rather than reacting to knock that has just occurred. The system went on to be used in the 458 and other high-compression Ferrari engines.
    A full explanation can be read http://www.searchautoparts.com/motor...nse-technology
    The technology requires specific coils and spark plugs which were also fitted to the F430 from MY2008 onwards; that makes my life a lot simpler!
    Secondary air injection
    Some US F430 models have SAI but no UK models did. All Scuderia's have SAI to help get the main cats up to temperature quickly in the absence of pre-cats.
    "The secondary air system is composed of an electric pump controlled by a relay, two pneumatic valves that close the line when the system is inoperative, and a solenoid valve that controls the pneumatic valves by means of the vacuum provided by a connection with the plenum chamber.
    The secondary air system is activated by the ECU after a cold start and only when engine temperature is in the range -7 to + 40C. In these conditions the engine runs in "Open Loop" conditions. During this phase the Oxygen sensors signal is utilised to calculate the temperature of the catalytic converters, utilising a mathematical calculation model."
    Active blow-by/oil breather control
    The F430 oil breather system is passive. The Scuderia system is active and introduced revised plumbing containing a one-way valve, and an ECU controlled solenoid to optimise the oil breather system for certain operating conditions.
  4. #734
    663
    That's the theory covered so now on to the actual conversion of my car. I had planned for this to be a quick activity where I'd book in the car with Ed at Christian Lewis to remove the inlet manifold and fit the two injection looms, then I'd be on my merry way for what remaining good weather we have this summer. This would be an interim solution as the ECUs would log DTCs for the missing blow-by solenoid and secondary air system components that would be installed with the other required looms over the winter lay-up period.
    It hasn't quite panned out like that. I've been diagnosing a potential performance issue with the car, well, I say potential but it certainly is: where the old car would romp up to 160 this one will get to 120 and become a bit flat thereafter. The old car with after market manifolds left me quite impressed with its performance, whereas this one - despite the weight loss - leaves me feeling a little unimpressed.
    I checked the wiring plugs for the cam timing 'variator' solenoids and three out of the four had oil in them. This is a known failure mode of the solenoids have. With this discovered, and the cam covers needing to come off -
    and I already knew they needed a refurb which would take a month or so - I decided to take the car off the road now and get everything sorted in one go.
    Scuderia Engine Management Conversion - Parts List
    The parts list for my car is below - bearing in mind it already has the other Scuderia systems installed:
    - England/GB specific 16M/Scuderia ECUs. These are used so I've sent them off to FAI for both to be virginised for use with my immobiliser;
    - 16M central/rear fuse box loom - it contains fused feeds for the Ion module and an additional relay for Secondary Air Injection. It is 16M specific because of the Spider roof elements;
    - Right bank injection loom (HFM7 MAF, Ion module, Ion module power feed, secondary air solenoid, knock sensor connections removed);
    - Left bank injection loom (HFM7 MAF connector, Ion module connection, knock sensor connections removed);
    - Right side engine bay loom (Blow-by solenoid, Ion module CAN bus);
    - Left side engine bay loom (Secondary air pump);
    - Blow-by solenoid valve - Installed so no DTC code for its absence but ports blanked off for now until I fit the revised oil breather system later;
    - Secondary air solenoid valve - Installed so the ECU does not log no DTC code for its absence, but the ports will; be blanked off as I don't plan to install the secondary air system;
    - Secondary air solenoid relay (same 50amp relay as the F1 system) - monitored by the ECU;
    - 2 x Scuderia Bosch HFM7 MAFs;
    - Eldor Ion module.
    Scuderia Engine Management Conversion - F430 Injection Loom Removal
    This was a fiddly job - in fact one of the most fiddly jobs I've done on a car. Access to most fastenings is tight.
    I had previously retrofitted coil water guards which I covered in a previous update, and with them removed the spark plug loom on each side is accessible; they are secured to the cam cover with zinc plated P clips. As per the other P clips on the car the rubber has deteriorated and cracked.
    With the injection looms out of the way on each side the poor state of the cam cover powder coat is visible.
    Inlet manifold assembly removed leaving access to the injection loom. The tape used on the loom is terrible and dries out, frays, and falls off. It is not heat related as it happens elsewhere on the car.
    Cam covers removed. These are hands down the worst condition parts on the car! The problem is the cost saving approach taken at the factory: the powder coat is applied directly to raw aluminium parts i.e. no primer. The issue is exacerbated on the Spider if the cam cover water guards are not fitted.
    I've found a local firm who will do the job properly: a chemical strip to degrease and remove the existing powder coat, a blast with aluminium oxide to provide a key, an etch prime, and then finally the crackle finish powder coat. Cost is between 130 and 150 for both.
    Scuderia Engine Management Conversion - F430 and Scuderia Injection Comparison
    Photo to show my original injection loom removed and the new Scuderia versions I have to go back in. The green text/arrows indicate differences between the F430 and Scuderia versions.
    Additional junior timer type plug for the secondary air solenoid.
    The F430 knock sensors are no longer needed so I could remove them. The four cam phase, four knock, and two crank position sensors all terminate at the rear of the engine in the vee. Bizarrely, all use the same connector and they aren't keyed and instead rely on identification numbers taped to the loom corresponding sensor cable. Whatever works...
    Photo to show three of the four F430 knock sensors removed from my engine together with the Scuderia Ion module that replaces their function. The knock sensors are labelled 3 to 6 and those numbers are not included on the Scuderia loom i.e. the numbering system is directly compatible with the parts remaining on my engine.
    Variator Solenoids
    The variators optimise camshaft timing for the following operating conditions:
    "Engine idling: intake timing is retarded. Late opening of the intake valves minimizes valve overlap. This guarantees stable combustion and smooth idling.
    Low and middle revs, medium to high load: intake timing is advanced. Early opening of the intake valves creates high valve overlap. Exhaust gasses are partially re-burned which lowers combustion temperature and reduces emissions of NOx. Early closing of the intake valves at low revs improves volumetric efficiency.
    High revs, full load: intake timing is retarded. Late closing of the intake valves improves volumetric efficiency as a result of the high inertia of the incoming air.
    Each cam/variator has a 50 degree operating range: retard 25 degrees to advance 25 degrees.
    The variators themselves seem reliable but their control solenoids are not, or certainly the variant fitted to my car. The solenoids were introduced with the Enzo with part number 186563. These were superseded by 212422 for the Enzo and this type was fitted to my F430, but these were revised again and superseded to 250646.
    The solenoids are secured by a single Allen bolt and with that removed they can be withdrawn by slowly rotating them, whilst pulling away from the variator housing.
    Three of my solenoids had oil in their multiplug but I'm going to replace all four with the later part, for peace of mind. The photo shows the four original solenoids removed - they are covered in dirt as I'd temporarily stored them in a waste container.
    Exhaust Photo
    As I never posted one last time - a photo of the completed and heat-wrapped exhaust.
  5. #735
    1,733
    Mark does the challenge car have the scuderia sump / pump solution? - might be a source
    The crackle finish is so annoying it's just that stupid saving pennies whilst wasting Tenners kind of thinking.
    On the breathing I am sure the headers and airboxes are what is allowing my DMS remap to really shine.
    The breathing is now truly race-like and the exhaust when valves are open is basically a very short open pipe system. I run stock cats which are probably the limiting factor now but with valves closed it is still civilised and therefore what I am sticking too.
    Agree with the carpets thing 100%
    For me it's the most pointless part of the Scuderia/ 16m package and would only be worth it if the chassis and its welding were a thing of beauty.
    Mine were even more fugly than I thought they would be.
    Tyres and engine mounts will be my winter job along with fitting the uber rare - genuine in-car telemetry option - I have a second copy of this kit if you are interested PM me as usual - I only have one software disc so we would have to duplicate it to install but apart from that it's 100% there and somewhat less than the 9k option it was. While you are in the loom it's would make sense if you want to do it.
  6. #736
    663
    Yes, I think the Challenge car does have it. It is the same part.
    I will have mine remapped next year
    Thanks for the offer on the telemetry. I will give it some thought.
  7. #737
    663
    Another winter project carrying on the weight saving. The below is from a previous update:
    "I discovered when working on my cars that the external body panel covering the roof tray is made from thick fibreglass and weighs 12kg. It doesn't serve any noise suppression function so is fair game for weight removal."
    I've found a UK carbon fibre specialist who makes unmanned surveillance aircraft for the Ministry of Defence, and what separates him from a lot of the cosmetic carbon fibre producers is that he understands structure and the structural properties of carbon, and thus designing components for optimal weight reduction. For example he uses Nomex honeycomb foam cores and other structural elements to increase strength whilst minimising weight, together with various types of carbon mat depending on the application. It is a vaccum bagging process - so it's F1 spec autoclave stuff - but the cost/weight ratio would not stack up for this project. I have to say his results seem pretty damn good - I've posted a few photos below of his work in progress.
    I estimate a potential weight saving of 5kg. If I am happy with the work I will commission the following parts in carbon:
    - Front bumper
    - Rear bumper
    - Engine lid
    - Bonnet
    - Dashboard moulding
  1. New F430 Owner - Advice Please?
    By Demon in forum Ferrari Talk
    Last Post: 11-05-2014, 12:50 PM
  2. Replies: 5
    Last Post: 11-02-2013, 11:54 PM
  3. New F430 owner!
    By jez in forum Ferrari Talk
    Last Post: 30-05-2012, 09:39 AM
  4. New F430 owner
    By gary.taylor17 in forum Ferrari Talk
    Last Post: 22-01-2012, 08:12 PM
  5. New F430 Owner saying hello
    By Nilesh in forum Ferrari Talk
    Last Post: 22-01-2012, 08:08 PM
