AJ.
If you haven't done it already, seal the floor. Keep the dust down to a minimum. Putting down either vinyl/plastic tiles act as great insulation too. The insulation you've got on the ceiling works well on the back of a garage door. Draught proof the garage door and you probably won't even need to put the heater on. I bought a few pics F1 off eBay, framed them for little cost. Would go well on that side wall.
The sign looks epic btw. I've still got my "Ferrari " to mount. That's the easy part . Where it goes????![]()
Andy it looks neat. I still have that same sign boxed up in the original packing. IIRC I got it around this time last year. The second picture is the box containing said sign
I still need to do plenty but I do have a cabinet in at the back of the garage, just to the right of the first image. I still have lots to do. There is a cabinet in the box on the floor almost next to the sign (out of view) and one on the other side of the full height cupboard but that does not even have the door on yet. Missus seems to have taken that over as an extension to the kitchen cupboards.
I have a auto door opener somewhere but it is never going to fit.
Never thought of that. I've just bought a rubber seal for the garage floor as I seem to be getting leaves a plenty and there is a definite draught if the door to the hallway is not closed properly. The door kind of has side baffles as in bits of plastic that sit on the frame when the door is closed, hardly seals the gap though. Does anybody recommend anything better?
Top of the garage door wiil be draughty too.i cleaned the edges up and used rolls of draught excluder.1 on frame/1on door so they just touch, but taking care ot doesnt affect rhe gap closure. Its fiddly but cuts out the draught. Problem with these doors are in the winter they act like a big freezer unit conducting the cold in. Unless you insulate them. http://images.tapatalk-cdn.com/15/12...07a89ec23e.jpg
Aj tiles i used were motile. They work well and are easy to lay. A single garage costs approx £450 to do it. I guess not quite low budget. Ebay sometimes can help with excess/used stocks popping up time to tme.
I painted mine a chequered flag pattern. Sealed the concrete, then used a carpet tile as a template to paint using garage floor paint - £20 a tin rings a bell.
It has stood up well over the last 4 years, minimal lifting under the tyres
I can recomend an insulated roller shutter door by Horman (German company) and floor tiles from Mototile in Fareham, I've used their standard tiles, choice of colours and style, they provide a design service and are very helpful, but if your floor is not very flat then it will need latexing.
Cheers. I will try the draught excluder strip for the door for this year. I have a floor for now, cheap but functional.
That sounds good, I'd make a right hash of painting it no doubt. I have sealed the concrete and put down a vinyl chequer floor for now. Glued it down so it does not move. It does leave tyre marks where the car has sat for even a few days. Eventually I'll sort something better out.
Door sounds good. Floor is perfectly flat, its only three years old in Feb next year. It would also mean my auto door opener/closer would work on that type of door I'm sure.
