Results 1 to 3 of 3
Thread: 308 carb door speaker grilles
    Aug 2013
    Surrey
    178
    Default 308 carb door speaker grilles
    Anyone have a set?
    thanks
    Sep 2018
    Ireland
    Andrew McCrae
    2
    Quote Originally Posted by penman12012 View Post
    Anyone have a set?
    thanks
    Hi Mark, Just joined the forum. I drew up Solidworks drawings (like you probably) and am having difficulty getting machining costs. I see elsewhere that you 3D printed them. I had thought of this too, Have you photographs of how they turned out? Were they expensive? I have been quoted for machining about $250 each in China and roughly the same here at home where I could control it better. This is unfinished before anodising! A pity noone else knows of other cars with a similar pattern.
    Sep 2018
    Ireland
    Andrew McCrae
    2
    Anyone have a set?
    thanks
    I gave up looking and just ordered Aluminium grills carved out of Solid Aluminium. Not cheap and they would only do 4 sets. I reckon somebody (who maybe has 3D printed or damaged will want at some stage. With me I'm too fussy to put on versions that are not as close as can be made to the original.
  1. 308 speaker grill
    By penman12012 in forum Technical Q & A
    Last Post: 10-10-2014, 06:34 PM
  2. Radiomobile door speaker cover
    By isuk in forum Wanted
    Last Post: 06-01-2014, 11:25 AM
  3. 308 GTS QV speaker covers
    By Tonym3 in forum Technical Q & A
    Last Post: 03-01-2012, 02:15 PM
  4. 360 front door speaker size?
    By Nikue in forum Technical Q & A
    Last Post: 23-11-2009, 10:21 AM
  5. 308 rear quarterlight grilles...
    By Murph7355 in forum Ferrari Talk
    Last Post: 11-07-2006, 02:47 PM
