Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: F430 window switch always illuminated
    May 2016
    Bristol
    David
    63
    Ok will have a further play around and see what is what.
    Thanks for the replies,
    954
    Quote Originally Posted by yewcheck View Post
    I have Mark, albeit a practical check by sitting in the car and operating the door handles to allow the windows to drop and also doing the same outside, and alll works fine.
    Could they still be at fault??? last time the drivers window would not drop when operating from inside, so quickly relised this was the problem and replaced the micro switch and the window switches wouldnt stay illuminated and battery never failed!
    Yes, absolutely. The switches are normally open which means in their default rest position they do not make a circuit i.e. when you are out of the car. If the switches have failed they can fail in the closed positon which means the window/lock module thinks the switch is being pressed all of the time thus keeping it from going to 'sleep'.
    Disconnecting the switches is a good test because it simulates their off positon i.e. a broken ciruit.
    swnyradar's Avatar
    swnyradar is offline Only useful for school runs - The Ferrari 308GT4 Club Member
    Jun 2014
    Wales
    Mike
    540
    I found that when I had my original fault with the battery draining, it would still drain even though it was connected to the conditioner, due to the window switches staying illuminated !
    Once I fixed the fault, I could leave the car for weeks and it would start every time. Thats why I would like this niggly issue fixed.
    Hi Dave, don't know if this is your first ferrari, but if you don't already know, they are made with fairy dust and magic and are unlike any other cars (good/wonderful + bad/nightmares) It may start after a few weeks but I would still recommend leaving the conditioner on 24/7 if you are not using it daily.
    From recollection, the window switch light does stay on for a prolonged period after shutting the doors as does the front boot light.
    May 2016
    Bristol
    David
    63
    Quote Originally Posted by swnyradar View Post
    Hi mate
    Yes the switches light up for around 5 mins after leaving / locking car, but mine never go off.
    May 2016
    Bristol
    David
    63
    Well guys thanks for all your help in this matter....I have found the fault😆😆😆 it was the locking micro switch at fault so ordered a replacement and also the inner handle one just to be safe,as this is the second one that has failed in 5 months.
    Once again thanks for all your helpfull replies 🖒
    Mar 2017
    Ipswich, Suffolk
    Will Finch
    25
    Hope that you don't mind me digging up an old thread.
    Similar issue with my F430, went to start it last weekend and battery was flat even though left on CTEK.
    Both window switch lights appear to stay on the whole time, also I note when you open the door the window drops about a cm as usual, but doesn't go back up for about 30 seconds after you close the door which seems a bit odd. Any thoughts on what might be causing that issue?
    Thanks.
    Mar 2017
    Ipswich, Suffolk
    Will Finch
    25
    Quote Originally Posted by WF36 View Post
    Thanks.
    Update to this post.
    Took the car to my specialist. The car had only been serviced at main dealer a week before the issue.
    Looks like for some reason they had taken the door card apart 1) put the microswitch back the wrong way and 2) broken the speaker connection.
    Not particularly impressed, think I will have a word with said main dealer on their thoughts!
  1. 348 Do they have a window limit switch?
    By irarref in forum Technical Q & A
    Last Post: 05-07-2012, 10:58 PM
  2. 348 Passenger Window Switch on driver's door
    By cgt in forum Technical Q & A
    Last Post: 23-08-2011, 05:29 PM
  3. 348 rear window switch
    By lea348 in forum Technical Q & A
    Last Post: 08-08-2011, 02:05 PM
  4. Calling Drew - 348 speedo and sticky window switch problem
    By candellara in forum Technical Q & A
    Last Post: 18-05-2009, 02:06 PM
