Results 1 to 10 of 10
Thread: 355 driving lamp stone chip removal
    Apr 2011
    151
    Default 355 driving lamp stone chip removal
    Being so close to the road, the 355's driving lamps are highly vulnerable to stone chips. After 52,000 miles, mine were cloudy due to heavy pock-marking of the surface. I contacted several headlight refinishing companies to get them ground and polished, but none of them wanted the work, preferring to deal only with modern, plastic lenses. I even tried plate glass repair and granite worktop repair companies, even a local optician, all to no avail. I decided to use some rare free time at home to DIY.
    There's very little information on the web about refinishing glass lenses, so I thought I would share my approach and results here. After removing the units from the front bumper and separating the lens, you can see the problem:
    I decided to correct the pitting using coarse sandpaper, then work my way up the grades before a final polish. Hand sanding would be a fruitless task, so I used 3" sanding discs attached to an electric drill. Lots of glass dust is produced doing this job, so it is important to wear a mask and use eye protection.
    Starting with an 80 grit sanding disc, I got to work removing the pits. There is quite a lot of heat build-up during this phase, so I used a water spritzer to keep the surface cool. Getting to the bottom of the pits took roughly 30 minutes and three sanding discs per lens. After that, it was a case of working up through 120, 180, 240, 320, 400 and finally 600 grit, each time removing the marring left by the previous grade. Up until the 320 grit, I was thinking "oh no what have I done?!" but as the finer grits were used, the lenses began to look much better.
    It was then time for a final polish. I made up a polishing paste using 20g of Cerium Oxide powder and a little water, then applied some blobs to a 3" glass polishing disc, then spent a few minutes passing the polishing disc across the face of each lens.
    The results were very pleasing:
    Considering that new lights come in somewhere over 400 a pair, it's a job well worth doing and really lifts the front of the car.
    Nosevi is online now There's an outside too? Where? Super Moderator
    10,867
    Great result and thanks for sharing
    milkshaker0007's Avatar
    1,197
    +1
    Thanks for the advise, great finish
    London/Kent
    Henry
    215
    That looks great. So many 355 are let down by these going cloudy. It makes such a difference to the front end having these smartened up.
    3,510
    lovely job....
    964
    Great work!
    Apr 2011
    151
    Thanks for the comments all!
    Now to sort out my sticky steering column cowl... and the other fifty things I want to tidy up
    Dec 2009
    CO5
    jonnyjonkers
    281
    Ha Ha, makes you wonder how much thinner the glass is now!
    Thanks for the advice, I'll certainly be looking at mine over the winter. Thanks also for sharing the moment of dread we all get when you think "Oh Lord, what have I done?!?" I now know to press on through.
    Afterwards I'd probably look to cover them, maybe a yellow wrap for the 'continental' look? (as kids we called them Bonjour Lights!)
    Apr 2011
    151
    They're now covered in (clear!) protective film waiting for the front bumper to come back from the bodyshop. I did consider thinning of the glass, but hey, it was either new ones or sand them, so nothing to lose. If you're keen to have a go, these are the products I used:
    http://www.pad-o-vac.co.uk/backing-p...cking-pads.php
    http://www.pad-o-vac.co.uk/sanding-d...ixed-grits.php
    http://www.pad-o-vac.co.uk/cerium-oxide.php
    http://www.polishedbliss.co.uk/acata...scs-cat10.html
    Dec 2009
    CO5
    jonnyjonkers
    281
    Quote Originally Posted by redwedge View Post
    Excellent, many thanks. I've subscribed to this thread for future reference.
  1. Stone Chip and Detailing
    By Iipboss in forum Car Cleaning and Detailing
    Last Post: 22-08-2013, 08:20 PM
  2. Stone Chip Shield
    By candellara in forum Car Cleaning and Detailing
    Last Post: 02-04-2013, 07:35 PM
  3. Any one know about 355 head lamp removal
    By ferrari-spider in forum Technical Q & A
    Last Post: 06-12-2012, 10:17 AM
  4. where to get replacement O.E. stone chip film?
    By scoobyc in forum Car Cleaning and Detailing
    Last Post: 30-10-2008, 10:56 AM
  5. Stone chip...
    By andy456M in forum Ferrari Talk
    Last Post: 14-03-2007, 12:34 PM
