Results 1 to 10 of 22
Thread: F430 track rod end rubber covers
    Oct 2015
    usk
    birdseye
    467
    Default F430 track rod end rubber covers
    Voicey says freely available universal covers, but every source I check says "not suitable for F430". Can anyone advise a suitable source. Or are universal ones OK and the websites reluctant to say so. If so, what size?
    2,264
    I think Mike(01606) may've been through this with his 360 and I'd expect them to be the same or very similar. Perhaps drop him a line...
    3,515
    I just bought shiny new HE track rod ends......
    The joints inside the OEM ones are still the chrome plated chocolate so not worth the pfaffage.
    peter white is offline Essex boy's Ford Capri Club Member
    Aug 2006
    Anglesey
    Peter White
    135
    I fitted new covers to my 360 track rod ends and posted photos and details of where to get them on 2nd Jan this year.
    Do a search for 360 Track Rod Ends Peter White and you should find it.
    If you have any problems finding it pm me.
    2,264
    Thanks, I had a look out of curiosity, it's here: http://clubscuderia.co.uk/forum/show...ds+Peter+White
    Oct 2015
    usk
    birdseye
    467
    Thanks Peter - I found it.
    Aug 2006
    Anglesey
    Peter White
    135
    As I said in my original post they do take a bit of effort (brute force) to fit.
    I put the boot in hot water and then squirted fairy liquid inside. After a lot of pulling and pushing it will go on.
    Finally I used a syringe (without the needle) and squirted some grease in between the track rod end and the boot, making sure it spread everywhere inside.
    Hope all this helps. Pete
    Titchfield
    Geoff T
    1,673
    Quote Originally Posted by peter white View Post
    I would be careful about using Fairy Liquid as it's quite corrosive, it contains a lot of sodium chloride (NaCl)
    Aug 2006
    Anglesey
    Peter White
    135
    Quote Originally Posted by geoffpfc View Post
    I hope that all the grease I squirted in which I then made sure was well spread inside by mounting the TRE in a vice (on the faces where the bolt goes through), and then agitating the arm for a good few minutes, will cancel out any corrosive effect of the fairy liquid.
    Oct 2015
    usk
    birdseye
    467
    Sorry Pete but no it wont. In effect you've put the boot on to protect the joint against road salt and then put some inside the boot. And the problem is that the detergent will make it easier to dissolve out the grease. Its not all going to dissolve into a pile of rust next week but I would have thought that it would affect the long term like of the joint.
  1. 360 Track Rod Ends
    By peter white in forum Ferrari Talk
    Last Post: 07-01-2016, 09:57 PM
  2. 360 Track Rod End Boots
    Last Post: 16-07-2013, 02:46 PM
  3. 328 track rod end boot
    By andyww in forum Technical Q & A
    Last Post: 19-11-2011, 11:18 AM
  4. 1343.30 to change a track rod end!
    By Charleyf in forum Ferrari Talk
    Last Post: 18-06-2011, 01:56 PM
