Results 1 to 10 of 10
Thread: high oil pressure
    Jun 2010
    Kent
    David
    218
    Default high oil pressure
    Started my 360 up today. oil pressure gauge immediatly shot up to 70. went for a run and pressure rose to the 140 mark at just a reasonable speed. If I put my foot down the needle went up to its maximum. should I be worried or will it be something simple.
    I would add that when stationary with the engine switched off the needle registers about a quarter of the way to the 70 mark so it might be the gauge?
    Halifax,
    ian
    1,577
    When mine did that it turned out to be a fualty gauge... i was always told not to worry about high pressure, it was low pressure that one had to be concernd with..
    mon the fish's Avatar
    mon the fish is offline Hey look at that Peugot 406! Oh no it's a Ferrari 360 Committee Member
    Jun 2013
    Aberdeenshire
    Gordon
    1,866
    On mine at the moment, it's only the edge of the bezel that's stopping the needle from moving further.
    When warm, I currently have approx 170psi according to my gauge [emoji23] My indie is looking into it...
    Sent from my SM-G900F using Tapatalk
    Windsor(ish), UK
    2,027
    It's very probably the sender unit which is a fairly painless fix. We had ours changed a year or so and it immediately cured our sometimes erratic display on the gauge.
    Balmullo
    Dave McGuire
    1,425
    Have exactly the same problem with my 360, also dial lights not working!!
    May 2016
    Mr McKay
    14
    Same problem here. Getting the sender (and o-ring!) changed at the next service. Hopefully will sort it.
    Jun 2010
    Kent
    David
    218
    confirmed as dodgy sensor. All sorted and pressure back to normal (phew)
    3,011
    I fitted a new one several years ago....I think it is almost a service part.
    The same sensor for other cars is about 20. Not a quality part!
    Jun 2010
    Kent
    David
    218
    20? if only
    The new sensor was 109.18 plus vat. Which come to think of it Is about 100 more than my mates 1997 Citroen XM is worth.
    happy days
    3,011
    Quote Originally Posted by Jagman View Post
    20? if only
    happy days
    I know.....I paid about 85 about 4 years ago.
    A comparable sensor from the same supplier was about 20 but needed a bush to fit the 360 thread. It would have made no difference but I couldn't do it!
  1. 360 Oil Pressure reading very high
    By transcup in forum Technical Q & A
    Last Post: 23-06-2013, 11:55 PM
  2. Replies: 0
    Last Post: 30-07-2012, 11:01 PM
  3. High oil pressure on 355
    By Carper in forum Technical Q & A
    Last Post: 28-03-2011, 06:45 PM
  4. High Oil Pressure on 360 Manual
    By DCramp in forum Technical Q & A
    Last Post: 26-04-2010, 12:30 PM
  5. 355 High Oil Pressure!!!?
    By 355marcus in forum Technical Q & A
    Last Post: 18-08-2009, 05:46 PM
