Page 27 of 32 FirstFirst ... 172526272829 ... LastLast
Results 261 to 270 of 318
Thread: My Argento 360
  1. #261
    3,528
    Quote Originally Posted by MalcH View Post
    I have been told by a local Indie that removing the resin/glue/epoxy is a right PITA.
    I has to be done though otherwise the circlips donít seat properly.
    A set of dental picks is the best Iíve got but it is very hard to clean out....
  2. #262
    761
    Mike,
    Had this on another car, and dental pick type tool was the best I could do. Took time, and easy to scratch the aluminium.
    My "dental pick" type tool was in fact a bent watchmakers screwdriver! Not pretty by any measure but did the job.
  3. #263
    Oxfordshire
    Andy Chadwick
    1,203
    I used these and a very small flat head screw driver.
    https://www.toolstoday.co.uk/teng-to...mer-set-ttsr04
  4. #264
    3,528
    Quote Originally Posted by achaddy View Post
    Cheers Andy....
    In the end a reasonably small flat bladed driver side on did the trick.
    Nearside all finished tonight just the ARB and drop links to fit in the morning as I need to do that outside.
    The ARB was pretty scabby on the ends so I had it blasted and powder coated.
    Before..
    Attachment 154020
    After
    Attachment 154021
    I found a great little metal finisher called Cheshire Classic and Custom near Tarporley. Highly recommended.
    Iíd picked up some air box covers a couple of years back so threw them in the car also...
    The guy took real care with them after my last issue with powder coating and they came out great considering they were really tatty going in.
    Iím dropping my 250 LC heads and barrels in for powder coating next.
    Attachment 154022
    It slightly bugged me that the calliper bolts arenít painted, so another concours point dropped by colour matching them to the calipers
    Attachment 154023
    I set the new spring (white code) compression to a mill or two less than the old one (yellow) but forgot to take an after pic.
    All finished....
    For those posting pics of their spacious garages. Hereís my work space ...
  5. #265
    Oxfordshire
    Andy Chadwick
    1,203
    Looks similar to what I have in my garage Mike. I always made sure the work area was at the front of the garage so you had the entrance/ourtside to manoeuvre if required.
    Putting the wheels back on was fun though with such little room to get your body behind to lift.
  6. #266
    3,528
    Roll bar goes in from the RH side quite easily especially is you have both sides of the car off the ground to access the space behind the front boot.
    No need to damage the £100 damp membrane! Removing the boot liner lets a lot of light through which helps.
    I was given a set on Ferrari 360 valve caps..
  7. #267
    3,528
    Ferrari ride height gauges. I might put these into production
  8. #268
    2,271
    Put them in a yellow and black box and you'll make some serious money.
  9. #269
    kensworth
    paul elton
    206
    Mike probably made them out of a yellow and black box.
  10. #270
    MalcH's Avatar
    11,577
    On the garage room post, marginally more than me. I'm sorry I had to. I am suffering garage envy of just about everyone on CS I think
    Just been looking at the other Mike's garage. I envy his, garage, his car, his house and its location. **** it whilst I am at it, he's younger successful and probably better looking. I'm ****ed
  2. Argento Strad for sale
    By 15hn in forum Ferrari Talk
    By steve f in forum Lounge
