Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: Advice required: 2006 Manual vs 2008 low mileage F430
    2,714
    Quote Originally Posted by thecook View Post
    Each to their own but I love the F1 in my 2005. To me it is hugely engaging in that you have to think about getting it just right. And when pushing on the kick in the back is magic.
    Last sentence nails it for me but there are many versions of F1 and the difference between a properly set up
    System and one that is needing adjustments / new parts can be staggering.
    Interesting take on the 360 and could be real world correct for many drivers. Purer lines in the design too (even as a 430 owner) but would have to change the headlights for me as I find the std ones really dated.
    Interesting blend of tastes in this thread.
    Sep 2017
    Cotswolds
    Patrick
    39
    I've been really impressed with the F1 box and at full "chat" its brilliant!, I've found it really quick in race mode and when driving more normally its perfectly useable. It maybe that mine is an 2008 so latest software and equipment but the F1 box gets such a hard time and its completely unnecessary in my experience, maybe an early 360 system was a bit questionable but its something I've not experienced.
    It has some quicks but it adds to the theatre of the car for me, I also know I can't change gear as quickly as the F1 nor downshift 2 cogs as quickly on the bends. I do feel comparing a 458 to a 430 is pointless its twice the price in real world so should be twice as good!
    GLWTS and go with the car your going to enjoy the most as thats the greatest value add there is
    1,442
    Quote Originally Posted by cgt View Post
    A 360 will deliver similar thrills, less to go wrong (e-diff particularly)
    I will swap the 3 year belt change on the 360, for an e diff and chain driven cams on the 430 all day long
    Also I think the model markets are overlapping with manual low miles 360 about the same cost as a high miler F1 430, and at the other end a low mile manual 430 about the same cost as a high miler 458. Throw in the price premium on spiders and this does give people a bit more choice in their particular budget range
    phillg's Avatar
    phillg is offline Looks like a 308 to me? -The Ferrari 288 GTO Club Member
    Nov 2006
    Dorset
    Phill Grimshaw
    2,639
    Quote Originally Posted by sssdu01 View Post
    Beware that Ferrari have added a chain inspection to the service schedule at 43250 miles.
    Major cost , and is around 3k to 4k at a main dealer. Nobody seems to know why it's been added.
    Spider,or coupe? Just get one of each.
    Bucks
    cgt
    6,242
    My experience of running both was that the 360 was cheaper due to less complication.
    I'm not 100% convinced by electronic reliability on the 430 and most are now over 10 years old.
    Sent from my SM-G955F using Tapatalk
    2,714
    Quote Originally Posted by phillg View Post
    The 430 has been the most electronically reliable tipo for my experience with ZERO issues and it's the Ferrari I have owned the longest.
    The chain inspection is almost certainly due to low mileages across the fleet. Some items have been added some removed for example evap system canisters which are replaceable for Maserati at 43250 have been lifetime removed from the Ferrari schedule. It's well known that the high miler cars are tracked by the factory for issues but so too are the low milers. Currently 599 GTO oil pumps are dropping like flys - cause? Lack of use.
    1,442
    Maybe its because Ferrari dealers have realised that they might have less work as the fleet moves to chain driven cams . What will they dream up next ??? a whole list of advisable items as we have taken your engine out sir ???
    964
    I thought the chain stretch check was always part of the service plan? It was in the handbook on my 2006 car.
    TBH I see changing the rod bolts as more important at 40k, and actually I probably will do have them done in addition to a chain check. I'll get a price for APR and compare to the uprated challenge versions.
    There have been more bottom end failures than anything to do with the timing chain and associated parts. Now I know more about the engine and rod ratio thanks to the person who is going to port my heads, I understand why.
    1,442
    Mark, not seen any rod bolt issues , tell me more just on the off chance that I might go over 4,000 revs once a year
    If they are an issue the APR bolts are probably the best bet. Also can this be done on a ramp with the sump off ? i.e can you get a bolt stretch gauge on to check the lengths without some thing else getting in the way ???
    964
    I've now seen four engine failures. The incidents aren't known because of fear of the cars' value being affected. The (very) knowledge engine builder I deal with has direct experience: the big ends become oval and "It only takes a few 100's of a millimeter before it fails.".
    I'm going to check mine at the 40k interval.
  1. Really low mileage cars - don't quite get it....
    By Nosevi in forum Ferrari Talk
    Last Post: 24-09-2014, 11:43 PM
  2. What to look out for on low mileage 360
    By dermot in forum Ferrari Talk
    Last Post: 20-03-2009, 09:22 AM
  3. Very low mileage cars
    By Webber3 in forum Ferrari Talk
    Last Post: 23-02-2008, 04:48 PM
  4. Low mileage 355's
    By candellara in forum Ferrari Talk
    Last Post: 21-11-2007, 09:34 AM
