Results 1 to 3 of 3
Thread: F430 - A Pillar Trim Removal
    Aug 2017
    Horley, Surrey
    Nigel
    1
    Question F430 - A Pillar Trim Removal
    Hi all,
    First post after 1 month of 430 ownership, so please be gentle !
    I'm in the process of sorting out the sound system in the car, on the odd occasion that the exhaust note isn't wanted. I've replaced the headunit for a more modern one, replaced the door speakers with JL Audio components, installed dynamat, and fitted a small active sub behind the passenger (can be quickly removed if required).
    Anyway onto my question ... I have a small windscreen mounted DAB antenna to install and you need to stick in to the screen on the passenger side and earth it to the A pillar.
    Q: How do you remove the A pillar trim ?
    Many thanks in advance
    Nigel
    jos's Avatar
    18,868
    Default Welcome & enjoy
    No idea how to dismantle a 430 interior but I suspect one or two people who do will be along shortly
    753
    From memory:
    Remove the sun visors - this enables the upper trim piece to be lifted in each corner near the top of the a pillar trim, to reveal a fixing. There is another fastening half way up the A pillar, underneath the exterior door seal.
    The bottom is slotted in on top of the dash, but the flap that comes down and covers the area near the vent/glove box I. E. facing the driver (I hope that makes sense!) Is held with two push in clips. Be careful as that part of the trim is not strong - lever it off gently.
  1. 360 Trim Removal Question
    By Doktor Evil in forum Technical Q & A
    Last Post: 08-05-2014, 05:28 PM
  2. 360 Spider Gasket (A Pillar > top of screen > A Pillar)
    By V8Duke in forum Technical Q & A
    Last Post: 03-04-2013, 07:07 PM
  3. 348 Seat and Trim Removal
    By irarref in forum Technical Q & A
    Last Post: 20-01-2012, 11:13 AM
  4. Removal of 3.2 Mondial trim,gutter and doors
    By jonathan.mccall in forum Technical Q & A
    Last Post: 12-03-2008, 11:38 PM
  5. 348 Door Trim removal
    By PAUL V in forum Technical Library
    Last Post: 02-04-2006, 11:50 AM
Tags for this Thread
