Results 1 to 8 of 8
Thread: F430 rear bumper (for challenge look modification)
    Ralph P is offline Pink pimped up Vauxhall Corsa Club Member
    Jun 2017
    Ralph Payne
    48
    Default F430 rear bumper (for challenge look modification)
    Hi all,
    I'm planning to fit a challenge rear grille so require a standard rear bumper which I'll have modified.... read as, cut down!
    I've had my eye on eBay for a while but it appears everything offered is damaged. Scratches and chips to the surface is acceptable, but cracks and damage to the mounts is not.
    In the unlikely event that anyone has a genuine "challenge look" option bumper available, obviously I will consider this too!
    Thanks,
    Ralph.
    Ps. Also require the challenge grille (Coupe version); must be as new condition.
    Dec 2011
    David
    109
    +1 Ralph but I'm happy to use my bumper and buy the challenge CF top part, need a bodyshop that is familiar with this job?
    Modificato is offline Looks like a 308 to me? -The Ferrari 288 GTO Club Member
    2,631
    Quote Originally Posted by dvb247 View Post
    Dave my detailer found a local body shop that did mine - owner has a 360 himself so did a precision job. Will dig out the details itís up Warrington way.
    Jun 2017
    Ralph Payne
    48
    A competent bodyshop will be able to modify your existing bumper, that is not in dispute.
    Personally I would rather acquire a second bumper and keep the original exactly that. I was hopeful the community would have some supply of standard F430 rear bumpers but apparently not!
    For any one else who is looking... this has been on eBay for months:
    https://www.ebay.co.uk/itm/RARE-GENU...MAAOSwKBFakeXB
    Price has dropped from around 700, to 595 and now 550. Offer a lot less than that though...
    This for me is overly damaged, so I haven't even offered. It has suffered a serious knock to the NSR and has damaged the mounts. A repair could be out by a few mm and result in panel gap problems. If it is worth a shot for someone else, go for it!
    Dec 2011
    David
    109
    Much appreciated Chris!!
    2,631
    Here you go http://prospray.co.uk
    Owner is Andrew Lennie.
    They made a scriber block to get the correct cut line and the work was immaculate and better than the factory examples I have seen.
    Dec 2011
    David
    109
    Awesome thanks Mod
    Jun 2017
    Ralph Payne
    48
    Bringing this back to the top in case an excellent condition but unwanted F430 bumper is out there....
    In order of preference:
    1. F430 rear bumper for carbon rear grille
    2. F430 rear bumper for standard grille, which I will then cut down.
    To compliment, I also require a carbon rear grille for a coupe, OEM part no. 80869800. New price is circa £2.5k so a second hand part would need to be materially less than this.
    I have seen and am rather tempted by Sforza's carbon rear connector Has anyone purchased any carbon products from them?
    Lastly, I mentioned back in May there was a damaged "carbon grille" bumper on eBay, which is still available...
  1. F430 Challenge rear bumper and grill
    By Doh in forum Wanted
    Last Post: 11-09-2015, 12:23 AM
  2. F430 REAR BUMPER ?
    By sean8696 in forum Technical Q & A
    Last Post: 27-11-2014, 08:16 AM
