Okay geek alert.
I know microns very well as I used to design two stroke exhausts. Anyway you can quiet the microns AND protect your engine for a long time with no loss of power as follows.
1) Remove The baffles with a pair of circlip pliers.
2) The baffle pipe in all but the latest designs was exactly the same length as the last ‘silencer’ section
3) What token silencing their was was wadding that was designed to burn out quickly to sound better !
4) if you have short baffles
5) simply extend them so that the pipe extends into the final convergent cone in line with its start
See below the classic quiet / longer stinger pipe and the stock microns baffles
The diagram below shows the stinger pipe concept.
Note power cut-off at peak power will be abrupt and reduce peak revs by about 400rpm BUT the bike will still sound cool but be socially acceptable-ish
