Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 67
Thread: Ferrari 308 Project Rebuild and Euro Conversion
    Oct 2009
    Wokingham Berkshire
    Scott
    245
    Getting there. That wiring...
    yer not great at all, but gradually figuring it out and fixing it.
    Oct 2009
    Wokingham Berkshire
    Scott
    245
    More progress today with the 308 project car.
    https://youtu.be/vZh9_he3xZc
    Oct 2009
    Wokingham Berkshire
    Scott
    245
    little bit more tinkering on the project today
    https://youtu.be/9-kbYIcqYCc
    742
    Scott - Have you taken the fuel lines off the top of the metering head and measured the flow through the head? You might need to start further back than the injectors. They are also quite simple to rebuild with a little patience.
    I also replaced all the flexi pipes as both these and the rigid pipes were pretty gummed up! They are also notorious for splitting!
    Oct 2009
    Wokingham Berkshire
    Scott
    245
    1,441
    Quote Originally Posted by spiderscott View Post
    Good luck with your project.
    I just had my first look at your youtube (episode 9 ) and just an observation I think they are too long with repeating the same information, and I think they would be better if you where more concise. e.g you could have said I got a new compression tester today and turned the first two minuets into 5 seconds
    963
    I would start looking at the valvetrain on the affected bank; It would be very unusual to have a bore issue on all four cyls leading to the same compression figures.
  8. #18
    6,636
    tempted to suggest a cam timing/ belt issue, maybe it slipped some teeth that's taken the valves out
  9. #19
    963
    That's what I suspect - I'm unsure what access is like on the 308 but its hopefully something that can be checked in-situ.
  10. #20
    3,499
    Caught up tonight and enjoyed the vids to date.
    i must say I admire your commitment working on a narrow drive in winter with no weather protection or light. Iíll not complain about my narrow garage again
    Iíd echo the other comments about a possible valve timing issue......
    Keep the updates coming......
  1. 308 With a Dino Body Conversion???!!!! Yikes
    By irarref in forum Ferrari Talk
    Last Post: 07-12-2013, 05:19 PM
  2. F355 rebuild project
    By David007 in forum Ferrari Talk
    Last Post: 28-04-2013, 11:28 AM
  3. 308 QV Euro - Change clutch cable ...help anyone ?
    By jasper_40 in forum Technical Q & A
    Last Post: 10-02-2013, 08:28 PM
  4. Why is a Ferrari engine rebuild so expensive????
    Last Post: 15-10-2012, 06:35 PM
  5. £500 Ferrari !! - Another cheap rebuild project ?
    By 400SPYDER in forum Ferrari Talk
    Last Post: 22-02-2006, 10:39 AM
