Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
Thread: Ferrari 308 Project Rebuild and Euro Conversion
  1. #51
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    Thanks for the info. Ive been doing a lot of research on this spoke with Alister @ Foskers and my friend Mark at Maranello and came up with the same conclusion.
    The good news is all of those bearings etc are available and in stock.
    So my plan is to investigate and remove the pulley and pray its something I can get to without having to strip it all down.
    fingers crossed
  2. #52
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    https://youtu.be/MnDYuNbwqXk
    new episode live on the 308 project
  3. #53
    747
    Hi Scott, I would have thought a decent impact gun would release the crank pulley bolt easy enough and a HE ring nut tool for the drive pulleys after locking the crank on the flywheel.
  4. #54
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    Finally got the right tools and was able to do some work on the 308 today
    Cheers for all the help and advice.
    Heres todays progress
    https://youtu.be/FuxMVXqOPCs
  5. #55
    1,035
    I like your videos, but not sure that is the correct environment to try and do what you are doing.
    You need to take that cover off and change both bearings, also you need to check that none of the bearing parts has fallen into the engine
  6. #56
    998
    Quote Originally Posted by PAUL V View Post
    I agree...
  7. #57
    1,442
    At the risk of sounding unkind I dont think treating a high revving/highly stressed V8 engine the same way as you would the engine in a £500 old banger is a good idea.
    I would want to take off the engine cover (even if it means an engine out), and check the insides are OK and at the same time change ALL the bearings and seals on that end of the engine. The bearing was so bad you cant see what other damage might have been done to the casing/shafts etc. Also if one bearing has gone that bad then the other might on the way out as well.
  8. #58
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    Agreed the engine needs to come out of the 308 and very likely the inner bearing needs to be replaced and shaft checked. This may also assist with the Euro conversion as manifolds, pipes and hangers all need to be changed and repositioned to house the differences.
    I'm having a rethink of the plan, that all needs to happen inside and in the dry. Ive got an engine out I want to do first on the Ratarossa ready for spring then i'll pull the 308 lump out.
  9. #59
    3,508
    Iím enjoying the vids Scott. Keep them coming...youíve certainly a lot of plates spinning
    I probably have about the same room at the side of my car, but at least a roof over my head.
    That bearing looked too far gone not to have damaged the inner one so a big gamble to not go further into it..
  10. #60
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    https://youtu.be/ClqCie3E2Mw
    Latest episode just uploaded, with some decent progress.
  1. 308 With a Dino Body Conversion???!!!! Yikes
    By irarref in forum Ferrari Talk
    Last Post: 07-12-2013, 05:19 PM
  2. F355 rebuild project
    By David007 in forum Ferrari Talk
    Last Post: 28-04-2013, 11:28 AM
  3. 308 QV Euro - Change clutch cable ...help anyone ?
    By jasper_40 in forum Technical Q & A
    Last Post: 10-02-2013, 08:28 PM
  4. Why is a Ferrari engine rebuild so expensive????
    Last Post: 15-10-2012, 06:35 PM
  5. £500 Ferrari !! - Another cheap rebuild project ?
    By 400SPYDER in forum Ferrari Talk
    Last Post: 22-02-2006, 10:39 AM
