Results 1 to 5 of 5
Thread: 360 HVAC Bulbs - where to find
    giles is offline Del Boy's Reliant Robin Club Member
    Nov 2012
    Midlands
    Giles
    52
    Default 360 HVAC Bulbs - where to find
    Hi Folks,
    Any suggestions other than the main dealer as to where I might get replacement bulbs for the HVAC control panel?
    Itís likely these bulbs are sourced for other vehicles and can be bought for pennies rather than the traditional high price from the Ferrari dealer.
    Any ideas?
    3,425
    Quote Originally Posted by giles View Post
    Hi Folks,
    Any ideas?
    Post a pic if you have one..... Iím sure it can be cross matched then.
    Nov 2012
    Midlands
    Giles
    52
    I canít see how to add a photo, just tried and it said upload failed.
    Iíll see if I can PM you.....
    3,425
    Hi Giles,
    If your using Tapatalk use the paperclip option rather than photo or camera.
    Nov 2012
    Midlands
    Giles
    52
    Success!
    Ok, Ferrari canít supply but you can get the Lucas bulb, however you need to remove the green tiny rubber cap from the bulb.
    Part number is: LLB286TFB1
    Just swap the green bulb rubber and you are away.
    Iíve just ordered mind from eBay at £2.75 each (4 required for the backlit panel).
  1. How easy is it change the brake light bulbs in the 360?
    By Angelis in forum Technical Q & A
    Last Post: 15-05-2017, 04:53 PM
  2. Where to find a 360 Modena front under tray?
    By nick_is_home in forum Ferrari Talk
    Last Post: 09-11-2014, 10:41 PM
  3. 360 Light bulbs..
    By olavskar in forum Technical Q & A
    Last Post: 30-06-2014, 08:30 PM
  4. Ferrari 360 A.C. Control Bulbs
    By Ferrari360Hamann in forum Technical Q & A
    Last Post: 25-08-2011, 09:24 PM
  5. 360 Headlight bulbs
    By Michael_360_Modena in forum Technical Q & A
    Last Post: 08-11-2010, 10:32 AM
