Results 1 to 5 of 5
Thread: F430 Spider Passenger Window sticking....(and driver's side squeaking)
    JohnJStewart's Avatar
    JohnJStewart is offline Only useful for school runs - The Ferrari 308GT4 Club Member
    Mar 2008
    Richmond, UK
    John Stewart
    548
    Default F430 Spider Passenger Window sticking....(and driver's side squeaking)
    First up my passenger window is behaving very oddly. When I drop the roof the window doesn't want to go down and sticks immediately then goes a bit wonky (technical term) as in it doesn't look straight. If I nurse it a bit with the window switch and a bit of fiddling it does go down and once it's past the first couple of inches it goes as normal. I've had a look at a YouTube of how to remove the door panel/car etc but to be honest the mechanism all looks a bit complicated on the schematics and unless something is obviously loose or broken then I fear wasting a lot of time to take off and replace the card with fingers crossed. Before I start does anyone have any thoughts on possible issues.
    Second up - my driver's side window has got the squeak from hell on lowering. It seems to be from the door rubber/window felt and I've tried some silicon but it doesn't stop it. Could this be an alignment issue? It raises and lowers fine but the noise is ridiculous and I am sure that Ferrari didn't design it that way (or did they!). Any ideas?
    dave964's Avatar
    Jul 2011
    Camberley
    1,311
    Whenever I've had odd behaviour with a window (not happened with the Ferrari yet), it's always been the regulator. I've replaced them on some other cars (my Alfa, and the 911 turbo I used to have) - not all that difficult.
    930
    Door cards off, moisture barrier off, then grease the mechanisms: the central cam gear arrangement, and both front & rear sliders.
    Use Lithium grease.
    Mar 2008
    Richmond, UK
    John Stewart
    548
    Default Window - thanks....
    Use Lithium grease.
    Thanks. Sounds like a fun weekend at some point. I've watched the online videos of removing the door cards and it looks a lot simpler than I know it will be!!
    Mar 2008
    Richmond, UK
    John Stewart
    548
    Default New moisture seal......
    Is this something that is available to buy? I usually find that the original is wrecked or I wreck it when I do these jobs, so a new one would be sensible.
  1. 35 gts5 Driver side window wont close
    By guappo in forum Technical Q & A
    Last Post: 14-05-2015, 08:32 PM
  2. 348 Passenger Window Switch on driver's door
    By cgt in forum Technical Q & A
    Last Post: 23-08-2011, 05:29 PM
  3. 360 Modena - Driver Side Window Play/Loose
    By dermot in forum Technical Q & A
    Last Post: 29-05-2009, 03:56 PM
