Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Resin Water Filters
    achaddy's Avatar
    achaddy is offline Only 37 known common faults - The Ferrari 355 Club Member
    Oxfordshire
    Andy Chadwick
    1,159
    I have one of these from Mark and it still leaves spots on my car so still have to dry it down with a towel.
    Leaves horrible tide marks on the 458 front aero wings as it is a concave shape so a small puddle collects there. So if I forget to soak up the water a nice mineral ring remains.
    Donít have a particle reader so donít know how well it is working or ever worked. Only had it 2 years I think and itís not used that often so the resin should still be good.
    Just my experience.
    francisn is offline Post whore with no life, no friends, and a problem fitting into normal social circles Admin dude
    S. England, but Scottish!
    Francis Newman
    16,801
    Quote Originally Posted by achaddy View Post
    Just my experience.
    Buy a particle checker to make sure it is working OK. Mark sells them but I bought one from Amazon for about 10 quid. Also useful for checking my home water softener is working properly.
    Nos
    10,610
    Quote Originally Posted by francisn View Post
    +1
    I test mine before using it each time and it gives near zero ppm having been through the filter, probably have pics to show that somewhere. No particles means thereís no impurities to leave a mark other than what the water pics up from the air while itís evaporating. If youíre getting marks my guess is itís not working properly.
    achaddy's Avatar
    Oxfordshire
    Andy Chadwick
    1,159
    +1
    Cheers guys. Will get a meter to see what the reading is
    Mark Wibberley
    1,224
    A few pointers on use of these:
    1. You do need to run some water through them every few weeks, about every 2-3 in the summer when its warm, as bacteria can grow in the warm, damp environment. This coats the resin, rendering its performance less than optimal. If the inside of the tank smells of fish, thats your issue. If so, pour in 2-3 capfuls of bleach, backflush (connect wrong way round) at low mains pressure for 1-2 minutes and once water smells pure, reconnect correctly.
    2. Ensure the hoses are correctly connected to the IN and OUT stamped on the head.
    3. One of the common causes of 'water spots', as Pete says, is dust settling on the water surface or water beads, giving the impression of spots. if they wash straight off, this is the case.
    3,430
    It might be grim up North but at least our water is pure and clean
    Iím fascinated by these threads as I donít think Iíve ever seen a water spot using Walesí finest.
    MalcH's Avatar
    11,504
    Agreed. I am curious though and may get myself a particle accelerator for checking my water
  1. Water Fiilter: Resin Change and TDS Meter
    By irarref in forum Car Cleaning and Detailing
    Last Post: 29-07-2014, 03:40 PM
  2. Worldwide launch on Club Scud - RG Water Filters
    By MoreThanPolish in forum Car Cleaning and Detailing
    Last Post: 06-05-2013, 02:02 PM
  3. De-ionised water filters
    By LazyLobster in forum Car Cleaning and Detailing
    Last Post: 23-08-2012, 07:13 PM
  4. Re-attaching resin shields
    By GreigM in forum Technical Q & A
    Last Post: 07-12-2007, 10:45 PM
  5. Removing resin wingshields
    By candellara in forum Technical Q & A
    Last Post: 06-05-2007, 03:34 PM
