Results 1 to 4 of 4
Thread: Ferrari F1 System Actuator Stripe down and Repair - Transmission Gearbox
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    Cool Ferrari F1 System Actuator Stripe down and Repair - Transmission Gearbox
    Guys Ive just put this video together of my strip down and repair on my 360 F1 Actuator that had failed, figured I would post it here to as it might help out in future, if you have a Actuator issue on your cars and are curious to know whats inside, what fails and maybe try and fix this yourself.
    There were two previous videos to this (both on my channel) detailing the problem I had with my 360 (no gears able to select and stuck in neutral) and some initial diagnosing of the parts trying to narrow down the potential component and also understanding the system a bit better myself.
    Special thanks to Aldous (voicey) AV Engineering and Mike who both really assisted me in understanding and learning the system myself along with their help to diagnose the problem.
    Any comments or other suggestions more than welcome.
    Hope it helps
    https://youtu.be/uBJFgoy2QyM
    Oct 2009
    Wokingham Berkshire
    Scott
    246
    Default F1 Actuator - Rebuild and Repair
    Final video on the F1 Actuator for 360, 430, Enzo etc
    In this one I:
    Rebuild and Repair, then reinstallation and all the alignments including the Jig, plus the computer bleeding, centering and full setup process.
    Hope it helps
    https://youtu.be/GrXL9VrPHvE
    3,510
    Great progress Scott.....
    This will certainly help a lot of people in the future...
    2,250
  1. F1 Actuator leaking gearbox oil
    By transcup in forum Technical Q & A
    Last Post: 10-07-2018, 02:15 PM
  2. Replies: 1
    Last Post: 29-08-2017, 01:10 PM
  3. scary shavings in Ferrari 348 transmission
    By crxmaniac in forum Technical Q & A
    Last Post: 02-05-2014, 08:05 AM
  4. new dent repair system in usa
    By steve f in forum Lounge
    Last Post: 14-12-2008, 08:31 PM
Tags for this Thread
