Results 1 to 9 of 9
Thread: Ferrari 355 front wheel bearing replacement
    355OXO is offline No I'm Spartacus Club Member
    Apr 2006
    Whyteleafe
    Simon Stroud
    1,307
    Default Ferrari 355 front wheel bearing replacement
    Hi,
    Does anyone know if you can replace just the bearing on the front wheel, as I would prefer not to have to buy the complete hub. It would be helpful if someone could tell me the source where I get just the bearing.
    The part number on the bearing is BARB 636021
    Any help appreciated.
    3,442
    Typing that number into google turns up a standard SKF bearing. I’ve bought quite a few bearing in the past but can’t find who I used. I think I’ve used Simply and Wych bearings in the past.
    If you call they will be easy to help......
    Apr 2006
    Whyteleafe
    Simon Stroud
    1,307
    Typing that number into google turns up a standard SKF bearing. Iíve bought quite a few bearing in the past but canít find who I used. I think Iíve used Simply and Wych bearings in the past.
    I actually ordered 2 from Simply bearings but when they arrived they were different to the ones fitted. I will check with them on Monday.
    3,334
    ronrob's Avatar
    Oct 2007
    Var, S.E. France
    Ronald Brown
    862
    ....and it looks like world of supply based in the UK have them for forty-odd quid. Well done Jeff!
    3,334
    Just double check with someone like Terry to make sure! LOL
    80
    Quote Originally Posted by ronrob View Post
    Best to check its comparable quality though
    Apr 2006
    Whyteleafe
    Simon Stroud
    1,307
    Hi, be careful, that is the thread that i used to order my bearings stating SKF 62209-2RS1. These do not fit mine. I saw on an Italian site that said Ferrari had an agreement with SKF that they could not sell these bearing direct. also said the part number is 62209-2RS2.
    Please check first before ordering. Bearings are £40.00 each.
    Apr 2007
    Maresfield East Sussex
    Jez Moore
    1,452
    Quote Originally Posted by 355OXO View Post
    Have you removed your old bearing and checked the P/N on yours yet.
    Reading on line it certainly looks like others have fitted the SKF 62209 2RS1
    I used to sell bearings many years ago, 2RS is double rubber seal one on each side, I believe the end number refers to the rubber compound: 1 is standard and the 2 has a higher heat tolerance
  1. 456 GTA Wheel bearing replacement
    By Chiefapasohak in forum Technical Q & A
    Last Post: 06-04-2015, 01:07 PM
  2. 360 Modena Wheel Bearing
    Last Post: 23-10-2010, 01:33 PM
  3. 308GT4 Wheel bearing
    By del.gil in forum Technical Q & A
    Last Post: 23-01-2010, 12:25 AM
