Results 1 to 2 of 2
Thread: 360 oil leak
    dave964's Avatar
    dave964 is online now No I'm Spartacus Club Member
    Jul 2011
    Camberley
    1,383
    Default 360 oil leak
    Noticed yesterday that I have a slight leak. For some reason, I can't post a picture - although it lets me choose a file there is no 'ok' or 'upload' button so I can't actually upload the photo. But it's actually the same picture as in the first post of my engine issue thread.
    It looks like the oil is coming from above where it's collecting. Only thing above there is the oil filler - it looks like that bolts to the block and I'm guessing it's that join that's leaking.
    I had that repainted a few years back and it needs doing again. How easy is it to remove the filler neck part? I guess I need a gasket although I might have one in my engine gasket set.
    dave964's Avatar
    Jul 2011
    Camberley
    1,383
    In case anybody else faces similar :
    Dropped the car off for it's 500 mile oil change yesterday, and pointed out the leak to them. The filler neck does indeed bolt on, and is sealed with an O-ring - apparently, it's very easy to nick the O-ring when you put it back together - and you don't find it's leaking until you run it.
    I'm guessing I've had that leak since I had the filler repainted and haven't noticed in the last 3 or 4 years - although I find that surprising.
    I probably have the O-ring in the engine gasket set I bought, so I gave them the set back and told them to sort it out - it's the obvious time to do it when they're changing the oil anyway.
    Also asked them to re-paint the filler neck since the paint has all flaked off again - didn't seem too enthusiastic, but hopefully they will.
  1. Help! Oil leak on my 360!..
    By olavskar in forum Technical Q & A
    Last Post: 08-11-2014, 12:42 PM
  2. 360 Camshaft oil leak
    By geoffpfc in forum Technical Q & A
    Last Post: 10-10-2014, 03:10 PM
  3. 360 oil leak
    By penman12012 in forum Technical Q & A
    Last Post: 15-09-2013, 11:42 AM
  4. Oil leak 328
    By rask in forum Technical Q & A
    Last Post: 11-03-2012, 02:29 PM
  5. 360 oil leak
    By big g in forum Technical Q & A
    Last Post: 21-08-2011, 12:19 AM
