Results 1 to 4 of 4
Thread: 550 Barchetta - Check Engine light/ Slow down? Diagnostic Help
    Jun 2019
    Sussex
    Benson Massy Collier
    2
    Default 550 Barchetta - Check Engine light/ Slow down? Diagnostic Help
    Hi, Can anyone tell me if there is a standard OBD port in the 550 Barchetta? I can't find one?many thanks, Benson
    19,095
    Default Welcome
    Pretty sure OBD only became standard on 575
    Mar 2015
    Sydney
    Ian Riddell
    86
    There is a 16 pin OBD 2 connector shown in the Workshop Manual wiring schematics, but I think it's only standard on USA cars.
    There is currently a discussion on another forum (Technical section) on how to get a 3 pin Fiat adaptor to work with a specific OBD 2 reader. The gentleman there may be able to help you find the 3 pin plugs on the 550 on a non-USA car.
    CO5
    jonnyjonkers
    281
    Quote Originally Posted by Barchettabenson View Post
    I have a Dec-97 550 Maranello and there is no OBD port on the car; we'd read somewhere there was but we never found it!
    It sounds to me like you have a leak in the inlet manifold, mine was suffering from a similar issue recently and causing a mis-fire. Paul Whatling at Lancaster Colchester Ferrari ( 01206 652975 ) helped me and could well be worth a call.
    Good luck, Jon
  1. 550 Barchetta - Check Engine light/ Slow down? Diagnostic Help
    By Barchettabenson in forum Technical Q & A
    Last Post: 26-06-2019, 10:53 AM
  2. 360 - Check engine light on. P0442
    By RacingRed in forum Technical Q & A
    Last Post: 14-04-2012, 07:09 AM
  3. Replies: 15
    Last Post: 13-02-2012, 06:22 PM
  4. 'CHECK ENGINE' Warning light in 456M
    By Cool As Blu in forum Technical Q & A
    Last Post: 17-10-2011, 07:27 AM
  5. Strad - Engine Management Check Light
    By candellara in forum Technical Q & A
    Last Post: 15-06-2009, 12:59 PM
