Results 1 to 2 of 2
Thread: Testarossa Hot Start Fix
    Oct 2009
    Wokingham Berkshire
    Scott
    248
    Default Testarossa Hot Start Fix
    I've been experiencing a very embarressing hot start issue with the Ratarossa thats gradually got worse over time. It seems to be quite a common issue with the Testarossa starter system so I did a quick clean up of the solenoid and so far it's been working great.
    Took less than an hour all in and is just the cost of a sheet of fine grade paper and some metal polish.
    https://youtu.be/m3F9X90BXUw
    milkshaker0007's Avatar
    1,197
    Nice fix
    Happened all the time on my 328, same or very very similar starter motor to yours.
    Fitted new solenoid and brush box unit less than 15 never had an issue since.
    You can get all the parts still for those old Bosch starter motors, great unit
  1. 348 hot start kit
    By ben111 in forum Technical Q & A
    Last Post: 23-11-2018, 08:50 PM
  2. Testarossa Hot start isssue
    By Ollie in forum Technical Q & A
    Last Post: 09-10-2011, 09:34 AM
  3. 348 Hot Start Problem
    By Johnnyred in forum Technical Q & A
    Last Post: 26-08-2011, 11:22 AM
  4. testarossa cold start idles rough
    By ross in forum Technical Q & A
    Last Post: 15-09-2009, 05:53 AM
  5. 348 Hot Start issue?
    By burriana in forum Ferrari Talk
    Last Post: 12-12-2007, 02:04 PM
Tags for this Thread
