Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: 355 test pipes too short?
    Allandwf is offline Essex boy's Ford Capri Club Member
    Jun 2009
    Angus, Scotland
    Allan Fisher
    128
    Default Exhaust
    Quote Originally Posted by Red_SLR View Post
    When you say rings at each end what do you mean?
    Sorry, meant the flange rings.
    Aug 2014
    Simon
    120
    Oh ok thanks.
    Was just reading on F chat that someone had a similar problem and fixed it by starting at the back with the exhaust box to cat flange on far enough for no gap. Nip that up and attach the v clamp and then tighten the fixings at the manifold end.
    That seems to sound good to me! However I am not sure if I will end up in the same problem with a small gap at the other end....
    Still baffled by these exhaust gaskets they sent made of steel wool too!
    108
    Oh ok thanks.
    That sounds like the exhaust will be pulling the engine and silencer together. Doesn’t sound good to me, as you say you will end up with a gap at the front unless you deform the engine or exhaust mounts.
    Presumably the steel wool gaskets are meant to be used at the front in place of the steel ones. Assuming they are the same shape.
    Jun 2009
    Angus, Scotland
    Allan Fisher
    128
    Default Exhaust
    Quote Originally Posted by Ian355 View Post
    Are the exhaust mounts not slotted and sprung for this very reason? ( Again apologies if the 355 is very different from the 348.)
    Aug 2014
    Simon
    120
    Think so you can only adjust so far as the collars inside the spring mechanically stops you from going any further.
    I will speak to ES about the gaskets tomorrow and if they are correct I will give it another go!
    108
    Quote Originally Posted by Allandwf View Post
    Biggest problem I can see apart from pulling on the mounts, is the bypass valve pipe enters front/ top of the silencer so restricting movement of the top of the silencer. Then if the test pipes create a pull on the bottom of the silencer they will try and twist the silencer box, possibly causing problems in the bypass pipe.
    Aug 2014
    Simon
    120
    Good point might be worth me taking a few turns off those bolts then tighten it all back up after.
    Aug 2014
    Simon
    120
    ES have told me the new style gaskets are a replacement for the old solid ones.
    Aug 2014
    Simon
    120
    So an update I took them off and put them on again and its fitting up much better now. There is still a tiny gap about 1mm right in the gap on the flange. But it was like that on the old cats so should be ok for a month or so - my car is due a belt service so its all got to come off again anyway.
    Ran out of puff (30+c in the garage) so did not get the wheels back on but will get that sorted tomorrow and take it for a run.
    784
    So what was different the 2nd time?
  1. Ferrari 355 test pipes
    By THL360F1 in forum Sales
    Last Post: 20-05-2016, 03:53 PM
  2. 355 Test Pipes on Ebay - overpriced?
    By mina in forum Ferrari Talk
    Last Post: 02-03-2009, 09:55 PM
