Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Brighton Speed Trials, I want to run my 458 Italia ????
    Aug 2017
    Little Bentley,Colchester
    Eddie Walsh
    87
    definitely auto upshift in launch mode
    Hi Thanks, Great even better if it auto shifts in Launch mode takes a load of my mind, as the couple of times I have tried to do a quick start in manual mode ( Not Launch) I always hit the rev limiter before I could grab second, so I hope you are right, Regards DM
    Aug 2017
    Eddie Walsh
    87
    Quote Originally Posted by dinoman View Post
    I would think a cold slick will still be better than a cold P7 ??,
    The Temp monitors just monitor temp so they do not know what tyre you are running ???? ???.
    I have floored mine in the wet and all that happens is a little squirm before the traction control takes control and limits the power, and hopefully if it was wet I would not take part.
    I have no problem becoming a YouTube star ??? Regards DM
    Thganks for all the support and advice so far, Regards DM
    2,262
    Hi Thanks, I do not understand what difference slicks will will make to launch and create a expensive bang ?? surely the more grip I have the quicker I can get away at the start, which is what it is all about ??, Regards DM
    You're absolutely correct. However, when you consider the energy involved with the car trying to pull forward and slick tyres holding firm rather than spinning, all of that force collides somewhere between the engine and the wheels. Over the years I've seen 'what gives' although admittedly not in modern Ferrari's, more like everything from US muscle cars to storming air-cooled VWs to top fuel and funny car dragsters. Go for it, what could possibly go wrong!
    I'm sure it's be fine, just be aware.
    Aug 2017
    Eddie Walsh
    87
    Hi Thanks again, I am sure the traction control will not differentiate between Slicks and normal P7's so there will be minimal spinning involved, as the traction limits the power to the grip you got, so no worries the computer is in control ??, Regards DM
    98
    Fairly sure that Mark was pointing out by having more grip, slicks will put extra strain on the drivetrain and so increase the risk of failure.
    Aug 2017
    Eddie Walsh
    87
    Hi Thanks, I am sure the Ferrari test drivers will have put a lot more strain on the drive train than I will ever be able to do ?? and if it breaks then it is all in a good cause, Regards DM
    19,094
    you need a Competition Licence
    https://www.motorsportuk.org/Get-Started/Starter-Packs - maybe a hundred quid plus probably a grand in helmet overalls gloves boots etc plus a couple of hundred entry fee - all for a few seconds of fun !
  8. #18
    Aug 2017
    Eddie Walsh
    87
    Quote Originally Posted by jos View Post
    Hi Thanks, hopefully 2 lots of 12.?? seconds of fun, Regards DM
  9. #19
    98
    Iím not sure if they still do it but several years ago FOC organised high speed runs down a disused airfield in Norfolk. Speed trap at the end of a mile + straight. Cars were model grouped so we were pitted against the same model. 355s were in the 160s 360s a few mph faster. I believe a F40 was around the 180 to 190. Some scrub/ small trees at the sides which gave good sensation of speed.
    It was a good chance to experience high speed legally. Crash cart and paramedics were there but just a crash helmet needed. Most cars did around 5 or 6 runs so a good chance to get the take off and gear change points right.
    Might be of interest to you or at least worth an enquiry.
  10. #20
    Aug 2017
    Eddie Walsh
    87
    Hi ian,yes that sounds a lot better Thanks, I will make some enquiries, Regards DM
  1. Brighton Speed Trials 2009
    By 208 GT4 in forum Meets, Cars & Coffee
    Last Post: 12-09-2009, 09:12 PM
  2. GT4 at the Speed Trials
    By 208 GT4 in forum Ferrari Talk
    Last Post: 15-09-2008, 06:30 PM
  3. Brighton Speed Trials - Sat 8th Sept
    Last Post: 09-09-2007, 05:34 PM
  4. Brighton Speed Trials
    By Murph7355 in forum Ferrari Talk
    Last Post: 03-02-2007, 01:10 AM
  5. Brighton Speed Trials - Sat 9th Sept
    Last Post: 28-08-2006, 12:12 PM
