Results 1 to 9 of 9
Thread: 355 Fuel line replacement. When ??
    Sep 2012
    In the Garage
    db188
    8
    Default 355 Fuel line replacement. When ??
    Hi I have been looking at when the fuel lines should be replaced on my 355. Are the lines date stamped and if so where is the stamp ?. I know new lines are not cheap but looking at a lot of photos of burned out 355's it looks as though the fire starts near the fuel lines !. Also if I ordered new line from Ferrrari would they be old stock but at least they wont have had fuel sat in them !!.
    19,087
    Sep 2012
    In the Garage
    db188
    8
    Thanks Jos Just seeing if anyone has an update. I suppose I should have gone back to my old post. I haven't used my car much but it is something on my mind so will try to get it done over the winter/spring.
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,917
    Quote Originally Posted by db188 View Post
    I have a few pictures from fuel line replacement I did on my 355b a few years ago. You may be aware of this but just in case.
    Old and new side by side. a very old recall was on the type of material on the fittings .
    The part number is stamped on the end fittings but I do not recall a date.
    I had damaged braiding (something else to look out for.
    Name:  IMG_4318 (Medium).JPG
    And a cracked fitting
    I would expect that all of this should have been done on any 355 these days, repeated here just in case
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,917
    This is the later recall on the fuel block:
    RC-98V058-NN.pdf
    The earlier one on the material type:
    Name:  fuel pipe mod.jpg
    Sep 2012
    In the Garage
    db188
    8
    Thank you Terry. Did you just purchase new factory ones and do they have a new part number to the old ones as they look a different colour !.
    Terry's Avatar
    Northwich, Cheshire
    Terry
    2,917
    I purchased new factory ones from Maranello for piece of mind. If you can find the correct fittings and hose, you could get them made up. Not sure how you would stand insurance wise if one leaked and your car went up in smoke.
    The table above shows both pre and post mod part numbers for a two pump early 355. If yours is a later car, upon checking the parts catalogue there is only one part number for each hose so no part changes just pipe routing to be careful with, and o ring seals on the end fitting of course.
    Not cheap parts but for a 20 year old car perhaps with the same hoses......
    At the very least, I would suggest a thorough inspection.
    Sep 2012
    In the Garage
    db188
    8
    Thank you Terry. Yes the problem being as you said is that they may be 21 years old now and i think preventative measures far out way what might/could happen !!
    Sep 2012
    In the Garage
    db188
    8
    I have I think made a list of the lines one of which 75 is not an updated number ! Mine is a 5.2 Motronic with 1 fuel pump.
    Diagram Number Quantity Old Number New Number
    56 1 165564 171342
    57 1 165566 171346
    58 6 127816 127816
    66 2 165533 171344
    67 2 165534 171345
    75 1 165565 165565 * I may need to check on this one to see if there is an update number.
    I think these will be around 1120 !!
  1. 355 Fuel line replacement recommendation
    By dib221 in forum Technical Q & A
    Last Post: 26-02-2018, 07:16 PM
  2. Ferrari 355 5.2 replacement fuel injectors
    By 355OXO in forum Technical Q & A
    Last Post: 26-08-2016, 06:39 PM
  3. 360 Fuel line crack
    Last Post: 10-06-2015, 08:58 PM
  4. 355 Fuel line - over or under?
    By Eric355b in forum Technical Q & A
    Last Post: 07-04-2015, 10:42 PM
  5. Fuel line recall info.
    By Pangea in forum Technical Q & A
    Last Post: 20-03-2015, 12:40 PM
