488 Front Brakes
JohnJStewart
My front brakes (CCM) are squealing and squeaking at low speeds, I have had it in the shop twice now and it just comes back after a few drives.
I would like to take the pads out and re-grease - DIY but can't find a really good tutorial. I have one loads of brake work before but am nervous about this one.
Can anyone help with an accurate description/video including where to place the axle stands after the car is jacked up. Thanks.
Before you go grease anything, I'd check what's actually causing the noise. Squeal that keeps coming back after the shop has been at it twice is usually not a dry-pad problem. With CCMs it's often just the ceramic dust and the pad material, and the noise can be normal at low speed. If the pads were bedded in properly and it still comes back, it's worth asking whether the shop used the correct shims and pad set for the 488 rather than just cleaning and regreasing.
On the DIY side, I wouldn't trust a generic tutorial for this car. Get the workshop manual procedure or ask a Ferrari specialist, because the caliper bolts and pad retention on the carbon ceramic setup aren't the same as a normal steel brake job. Also be careful with grease, as it should only go on the contact points and backing plates, never near the disc face.
For jacking, use the factory lift points (they're in the owner's manual) and put the stands under the reinforced sections of the sill or chassis, not on the suspension. Make sure the car is low enough to get the stands in without scraping the front lip. If you're nervous, a proper ramp or a lift is a lot safer.
