488 Tyre Inflator Replacement Bottle
JohnJStewart
Morning all. I had a tyre blow out and used the FixandGo Airflow in my car to try and fix it. I threw the used cylinder away and am looking for a replacement. The Ferrari ones seem to be around £100 but the FlexandGo website has them for under £20 if I can identify which one. I think it is a 400ml version - could someone please take a look in their 488 and send me some photos of the canister ideally with the volume and if available the part number. If you don't have the Airflex which one do you have - the model is only shown on the instruction manual not the unit. Thanks everyone.
Good tip for anyone else who ends up in the same spot. Now you’ve got a fresh canister coming, check the expiry date on it, as the sealant has a shelf life and these tend to sit in the boot for years unchecked.
Also, if it was a proper blowout rather than a puncture, I’d get the tyre looked at before trusting the sealant long term. It’s only meant to get you to a tyre shop, and on low profile tyres like the 488 runs, sidewall damage can’t really be repaired. This write-up on low profile tyres explains why they’re so much less forgiving, so it’s worth a read if you’re deciding between repair and replacement.
