I've had painting jobs done by Chartwell in Derbyshire previously including having jobs redone that were done poorly by others. Not the cheapest but what they've done has always been great quality.
The UK's only super brand bodyshop, with full structural approval from the world's leading supercar manufacturers. Setting the gold standard since 1966.
Worth getting a couple of quotes before you commit, as prices for caliper painting vary a lot depending on whether they do it with the calipers on the car or take them off. Taking them off and stripping them back properly is the way to go. Painting them in place usually means masking around everything and you'll see it in the finish eventually.
Ask what paint they use too. You want proper high-temp caliper paint or a 2K finish with lacquer on top, not just a standard paint, otherwise it'll discolour with the heat from the brakes. Yellow on an F12 will look great against the carbon ceramics if you've got them. Chartwell are a good shout if you don't mind the trip from Yorkshire, it's not that far.
