Re-attaching resin shields
GreigM
I've recently had to remove one of my resin shields (360) as I was getting a minor bit of paintwork done due to a badly repaired stonechip (started to rust underneath). It came off easy enough and is in good condition - can it be reattached? If so what kind of glue should I use?
I was thinking of going for yoshi's shields, but the wesbite seems to indicate they are $350 each (i.e. $700) - am I reading this correctly, or is it 350 for a pair? At $700 the reports of suspect workmanship,durability and service are putting me off.
If all else fails, I'll go get a new set of resin shields from the dealer - anyone know how much these cost?
Not worth trying to refit the Resin ones, buy new from Ferrari UK, cost is about £3.00 each
Resin shields from yoshi are nowhere near as expensive as you said. You can get lovely enamel shields for £260.00 (Includes Postage) from "wingbadges" on eBay. They are based in Sweden and do the Best non OEM shields for Ferrari.
$350 is for a pair from Yoshi
thanks guys, never realised the resin ones were so cheap - just assumed everything from the dealer was a minimum of 50 quid ;)
Thanks for clarifying yoshi's shield - just got confused when the ordering page on the site said:
Scuderia Fender Shield (Type-A)
and showed a picture of a single shield........
May try the yoshi shields as I have an address in the US so can get them next time I'm over...
Yoshi's items look great on the car.
And you were right about Ferrari tat being overpriced. At 3 quid the resin shields are about 50 quid overpriced :wink3:
Can someone retrofit the OEM ones with the recess as when ordered from factory so they look as they should from Ferrari or as a retrofit they can only be glued ( resin or metal) to the side wing ? If so is that easy job and who is good for this apart from a main dealer ? :)
