Does anyone know the maximum in gear speeds of a F355 or what the mph per 1000rpm in each gear is please?
Thanks
Thanks
Try: www.the355.com as a great source of info on this model.
Edit: there's some bird wanting to flog holidyas.... Ric355, have I got the site address wrong?
The numbers from Autocar & Motor road test published on 01 June 1994.
5 speed manual:
Ratios /mph per 1000 rpm
1st 3.07/5.9
2nd 2.16/8.3
3rd 1.61/11.2
4th 1.27/14.1
5th 1.03/17.4
6th 0.84/21.4
Final drive ratio 3.56
The above ratios are rounded to 2 decimal places, the WSM values are 3 decimals with one difference for 6th gear Swiss version cars (0.861). Pre and post 1998 ratios appear to be the same.
Nice one Terry - that's GREAT!
Hmm - found this - http://www.lotusespritworld.com/ERoa...Car_May96.html
which appears to be an early car reviewed and it has these ratios
1st 3.74 5.7
2nd 2.63 8.1
3rd 1.96 10.8
4th 1.55 13.8
5th 1.26 16.9
6th 1.02 20.8
which is strange because at 8500rpm would give only a top speed of 176.8mph rather than 181.9 as above.
