Results 1 to 10 of 22
Thread: 348 MAJOR SERVICE & CAM BELTS WHAT'S INCLUDED ?
    Jun 2007
    Nr Glasgow
    Zak
    825
    Default 348 MAJOR SERVICE & CAM BELTS WHAT'S INCLUDED ?
    I am going to be getting my 348 GTB Serviced & was wondering what is included (as per Ferrari Schedule) in a Major Service with Belts.
    Can anyone please reccomend any other things that should be done whilst the engine is out.
    Thanks in advance.
    Angelis's Avatar
    London/Essex
    Sy
    17,024
    Depends on how long you are going to keep it and what's been done in the past.
    I'd consider the following:
    - Change Cambelt Tensioners for ones from Hill Engineering.
    - Consider changing the water pump or at least check it (it'll be over 14 years old... buy OEM or the cheaper ebay one)
    - Get the dampers refurbished (60 plus vat each)
    - Change spark plugs for NGK's
    - Paint the cam covers
    - Change as many seals as financially possible (if you're going to keep it long term)
    - Change the coolant hoses for the silicon ones I put together from SFS
    - Check the Alternator bracket for cracks. Costs 24 to replace.
    - Consider also upgrading the Alternator with a couple of new parts. It'll make it more reliable and does'nt cost much to do.
    - Check suspension bushes for wear
    As I've said, the 348 is 14 plus years old now so many things need to be replaced. Rule of thumb is to purchase better parts where applicable. Things like Tensioners and spark plugs are better purchased elsewhere than Ferrari as they are better quality.
    Good luck
    Check out my engine out http://www.fgear.tv/forum/showthread.php?t=650
    In continent
    dasadrew
    1,531
    What's the OEM Water Pump Sy?
    (BTW, I'd add Thermostat + Seal to the list. PITA to do with engine in-situ)
    Fraccie's Avatar
    Dilligaf
    Ade
    25,945
    Earth
    19,741
    Depending on the mileage and whether you are doing the cam seals or not(which I would) it is worth checking the valve clearances and adjusting if required.
    I believe Dave at Scuderia Systems does a silicone hose set as well
    Personally I don't think these cars should now be serviced in line with the factory schedules, they need more than this
    Angelis's Avatar
    London/Essex
    Sy
    17,024
    Quote Originally Posted by dasadrew View Post
    It's the original Ferarri one which costs around 600.
    The ebay one is much less than that and supposed to be quite good with the correct bearing used. I purchased the Ferarri myself.
    Yep. That should be changed as well. Cost around 50 if I recall correctly.
    Contact Joe at lancaster ferrari and mention my name (Sy) and he'll give you a discount as well.
    Feb 2006
    Essex
    639
    Quote Originally Posted by Angelis View Post
    Joe does not even work there anymore .....
    Dale's Avatar
    Dale is offline Looks like a 308 to me? -The Ferrari 288 GTO Expert
    uk
    Dale
    2,613
    Quote Originally Posted by Zak348Gtb View Post
    Thanks in advance.
    This
    Angelis's Avatar
    London/Essex
    Sy
    17,024
    Quote Originally Posted by strad360 View Post
    ooops...and I was going to order more stuff from him.
    In continent
    dasadrew
    1,531
    that was a drastic edit!
  1. Club Scuderia Owners Club!
    By Gimme Fuel in forum Ferrari Talk
    Last Post: 18-07-2012, 12:09 AM
  2. Is the 348 a good Ferrari ?
  3. 355 cam timing.....
    By ferrari-spider in forum Technical Q & A
    Last Post: 04-12-2006, 03:05 PM
  4. 348 Cam Profiles
    By Littleblackflash in forum Technical Q & A
    Last Post: 20-04-2006, 09:04 PM
