Results 1 to 8 of 8
Thread: Can you help? - re Ford Streetka
    Oct 2008
    Essex boy
    Lord Adam
    5,606
    Default Can you help? - re Ford Streetka
    My girlf has an 04 Ford Street ka, you know, the little 2 seater soft top.
    She has a problem with the roof. When putting the roof back up (after it stores away) there is a part that kind of pushes in and goes out of allignment. So when closing the door it leaves an inch gap. This can be resolved using a crowbar and simply popping the part out again and back into allignment and everything is rosy again.
    However, she can't be using a crowbar everytime she has to put the roof up so she went to Ford and they said it a common problem. The only thing they can do is put a new roof on for £2k. I don't think the car is worth that!
    Can anyone help this poor little KA?
    Oct 2008
    Essex boy
    Lord Adam
    5,606
    Quote Originally Posted by Adz man View Post
    I'll take that as a no Off to see a welder that I know next week who should be able to take out the weak joint and replace it. Fingers crossed
    Murph7355's Avatar
    Here there and everywhere
    Murph
    14,313
    Sorry Adz. Can't help.
    My sister has one, but the roof's OK with hers.
    Have you checked all the attachment points to check they're all tight enough? If it goes back OK but goes out of whack, it sounds like something might be loose (or even too tight/something stuck in the mechanism?).
    Mar 2008
    Malta - at the pub mostly
    Xmun
    2,513
    The crow bar is being used in the wrong place -should have been used when the idea of buying a street ka was even considered
    Brighton
    Dan
    1,718
    It does sound like something's out of alignment causing loading of the part that bends. If you keep bending it, it will fatigue and snap sooner rather than later. It's the sort of problem a decent mechanic might be able to fix through adjustment, but I'd steer well clear of a main dealer on this one.
    Oct 2008
    Essex boy
    Lord Adam
    5,606
    Thanks chaps (apart from Ace )
    The welder I know can do anything within his trade, he's a real genius and he seems to think it's no major problem. Hope he still says that when he sees it!
    Murph7355's Avatar
    Murph
    14,313
    Unless you know that something has actually broken, I'm not sure I'd be getting a welder on the case...
    Jan 2008
    Richard
    1,091
    Expect he'll probably weld it shut. That'll fix it.
  1. Ford Street ka advice
    By Adz man in forum Other bikes, cars and toys
    Last Post: 03-01-2009, 09:08 PM
  2. Daytona 40th anniversary
    Last Post: 04-08-2008, 11:43 PM
  3. Knockhill June 8th
    By mark308 in forum Meets, Cars & Coffee
    Last Post: 10-07-2008, 12:27 PM
  4. Ouch Ford GT
    By MalcH in forum Lounge
    Last Post: 07-02-2006, 04:16 PM
  5. Shelby GT500.
    By fan512bbi in forum Other bikes, cars and toys
    Last Post: 10-01-2006, 10:25 AM
