Results 1 to 10 of 16
Thread: 348 Door Trim removal
    1,043
    Default 348 Door Trim removal
    Can any of you do me a favour
    I have taken the door cards off my 348TB and am a little confused how they are fixed, I know there are plastic clips and various screws that hold some of them on etc. The area where I have a problem it the end of the door (opposite to the door hinge) are there any screws in that end??
    The parts book lists 2 alloy strips called door upper moulding and door lower moulding but I cannot for the life of me understand how this attaches to the door. Any photos of the door end may clear this up.
    In continent
    dasadrew
    1,531
    I posted this on the dark side a while ago.
    Gimme Fuel's Avatar
    Gimme Fuel is offline Post whore with no life, no friends, and a problem fitting into normal social circles Club Member
    Sjasjbårr (Norway)
    Pål
    19,726
    Lightbulb How to get inside the door on a 348!
    I've had some problems with opening the passenger door from the inside on my car, so I decided to take a closer look at the problem today.
    And I thought it would be a good idea of taking some pics during the process, in case some of you might find it interesting
    This is how I did it, step-by-step
    The first thing I did was to remove the two strips from the outter part of the door.
    The door on the 348 has 4 different "sections/panels" - and I started by gently pulling off the lower section - the fabric.
    This section was held in place by 3 clips and no screws.
    (PS: The clips might break, so I recommend that you have some spare clips)
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 2.
    The next section was held in place by 4 clips and 1 screw...
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 3
    The door handle section was held by 3 main screws and 2 from underneath the door handle.
    Firstly unscrew the door handle and the small screw which holds the opener...
    Stick your finger under the panel and simply push out the window-lift button, and disconnect it from its socket.
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 4
    Unscrew the 3 main (big) screws on this section, note that there are also 2 screws up under the door handle.
    So in total here, you need to unscrew 5 screws and no clips.
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 5
    The top section is not connected at all.
    Just pull it gently off, remembering to remove the door knob first.
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 6
    Remove the 2 aluminium strips and the window strip- not a MUST, but its easier to work when its removed.
    Undo the 6 small screws and the window strip can be removed.
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 7
    Now, the tough part...
    Unscrew ALL the big screws from the inner door panel (10mm)
    TAKE NOTE OF THE 2 SCREWS CIRCLED IN GREEN
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 8
    The inner panel is now loose, so gently lay it down on something flat, make sure it dosent hang loose under it's own weight or it may strain the wiring.
