Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 348 Door Trim removal
    Gimme Fuel's Avatar
    Gimme Fuel is offline Post whore with no life, no friends, and a problem fitting into normal social circles Club Member
    Sjasjbårr (Norway)
    Pål
    19,726
    STEP 9
    Found my problem
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    additional Pic To Step 4
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    Remember those 2 screws circled in green?
    When you're putting this back together, you might struggle matching the holes with the screws. Those 2 green circled screws are actually held by the window-lifter - so you might need to lift the window with your hand in order to fit the screws.
    Also remember to have extras clips handy, in order to replace any old ones which may have become damaged!
    I'll continue this thread as soon as I've got a replacement wire!
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    Last pic....
    1,040
    The first thing I did was to remove the two lists from the outter part of the door.
    I think they are 2 bits of Alloy painted black? I have done what you have done removed all the door parts but my Lists as you call them i think are wrong or not the right shape any more so a photo of yours would help.
    Yes i could not work out the 2 holes i have had mine recoverd so they are not there any more.
    Gimme Fuel's Avatar
    Sjasjbårr (Norway)
    Pål
    19,726
    Here you have a better look of the strips
    They CAN be a PITA to reinstall but.....
    Hope this helps - if I'm off the mark, please let me know
