Results 1 to 10 of 12
Thread: testarossa cold start idles rough
    Feb 2008
    Reading Berks UK
    Ross lillywhite
    125
    Default testarossa cold start idles rough
    when cold, car will start for and run 1 sec, 2nd crank run for 3 secs , 3rd crank run at 600 revs as rough as anything and no throttle response, give it 10 mins and warms up and is perfect .cold start injectors / circuit presume fine, last owner said it was fine till laid up for a year..any ideas, will clean all elec connections tomorrow.
    Iain
    7,173
    Quote Originally Posted by ross View Post
    Start looking for air leaks around the CIS system & also splits in vacuum lines. The CIS warm up doesn't work properly unless its sealed.
    Feb 2008
    Reading Berks UK
    Ross lillywhite
    125
    cheers got this week off to do the brakes, and a list of probs will check air leaks, vacuum pipes and all connections too
    Iain
    7,173
    Alot of those hoses will probably be cloth braided (if its anything like the 308/328) & so its quite difficult to check them for splits & leaks etc. Think Automotive in Isleworth would be your best bet for replacing those.
    Also, trace/check the vacuum lines back to the engine management box(es) - found a big hole in the one on my 328 a while back that was well & truely screwing everything up (and that meant I was getting no vacuum advance on the timing either).
    Jul 2007
    sheffield
    clive p
    401
    Ross just a tip I read re testas, when jacking to remove front wheels advice is to jack both sides as screen so big it can crack if jacked on one side only. Dont know if this is genuine but they run approx 1000 and can be a real pain apparently.
    Good luck with the jobs this week mate and am enjoying your posts.
    Clive
    Jan 2009
    Fixing someone's f-car
    Ed
    622
    Try it with the plugs on the cold start injectors disconnected. The base engine mixture might be too rich, and when the cold start is on as well it would be very rich.
    Dale's Avatar
    Dale is offline Looks like a 308 to me? -The Ferrari 288 GTO Expert
    uk
    Dale
    2,613
    Ross WHO service's your car.
    Feb 2008
    Reading Berks UK
    Ross lillywhite
    125
    i have only just got it, previous owner said its been like it since it was for sale at a dealers for a year, so originally thought they,d steamcleaned and got water in somewhere.
    so working my way through a list of mechanical faults. at least i got the central locking working today.
    Feb 2008
    Reading Berks UK
    Ross lillywhite
    125
    Default fixed and ordered parts from usa
    been on it all morning but finally diagnosed rough cold start and running, found no voltage at temp sensor and traced back to fused relay in box under o/s/r wing. power to it,good earth, feed when cranking even but none out so linked out and now runs great . ferrari price just over 300. place in usa 1-3 days priority post $150 delivered
    just now have to reassemble car and hope relay arrives by saturday.... well pleased
    good old italian electrics,
    12 Cylinder Village
    Si
    13,437
    I got this relay out of a 928 Porsche or rather stevef did and cost me nowt works fine but does'nt have the fuse on top, yours will, did you get it from Ricambi they sell them at about 65 IIRC
  1. 360 Rough Start Up
    Last Post: 17-04-2009, 01:44 PM
  2. Mondial cold start
    By Trevsked in forum Technical Q & A
    Last Post: 14-08-2007, 05:14 PM
  3. Testarossa info wanted. Please be gentle.
    By renmure in forum Ferrari Talk
    Last Post: 09-05-2006, 03:54 PM
