Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Real fires and chimneys
    Feb 2008
    Reading Berks UK
    Ross lillywhite
    125
    Default Real fires and chimneys
    does anyone use a real fire in their home, bought a new house that has a real chimney, went out yesterday and got a grate, smokeless coal etc and had the chimney swept, tried to light a fire and within minutes thought someone had thrown a gas cannister in the house. had to open all the windows to find the children with their eyes streaming, mind the coughing told me where they were,i am getting the sweeper back as i have a tile on the chimney with only a small gap which is causing no draw, according to a neighbour.
    but can i use a real fire with no smoke at all in the house as i dont fancy redecorating every year, sorry its long but fancied the idea of chestnuts and marshmellows on the fire, as you can guess it was my first attempt.
    Iain
    7,173
    Quote Originally Posted by ross View Post
    If you have a proper chimney that will draw then no reason why it won't work surely? Chimney isn't going to draw with a tile on top of it though
    You also don't really want an open chimney pot - ideally it needs some sort of cowl up there to keep the rain etc out.
    Sep 2007
    Mappleborough Green
    J Heitmann
    1,365
    Even a small hole should be enough, mine doesnt smoke and I use it throughout the winter.
    Smokeless coal is costly, get some wooden blocks in there dude !!!!
    Jul 2007
    Surrey
    Mandy
    1,212
    I have a real fire, and also use wood rather than coal, add some Pine Cones they glow nicely
    I have a friend who has a chimney sweeping brush and just borrow it from time to time to keep it clean, not had any problems with smoke in the house.
    SE London / Kent
    Mal
    1,711
    The draw on the chimney depend on a lot of things including the size of the opening, the flue, the design of the throat and the natural ventilation.
    There needs to be a source of fresh air close to the fireplace in order to create an airflow. Houses today have double glazing, sealed doors etc which reduces the airflow. If the chimney has not been used for some time I would get it tested by a flue specialist to ensure there is no leakage in the flue - your sweep may be able to do this. The chimney may need lining to ensure it is safe.
    Clearly the chimney needs to have the tile removed
    Up North
    997
    If it's warmer outside than in then you will get a down draft, just hold your hand above the fire and you can feel a cool draft on the back of your hand
    Dec 2007
    Cambs, UK
    Rob
    1,964
    Quote Originally Posted by Iain View Post
    Pidgeons also like to go sliding down them sometimes. They will either appear in your lounge looking a bit confused and covered in soot or get stuck in the flue and die and rot, which smells delightful.
    If its an old house and the fire has not been used for a while it might be worth getting the flue checked for leaks.
    May 2006
    Angus, Scotland
    Jim
    1,471
    I have a few open fires and have had the same experience on a couple of occasions over the years.
    Assuming your chimney is ok (and open at the top.. get rid of the tile!!) then you can just be a bit unlucky with the wind blowing back down the chimney at the wrong time. If it happens often and there are buildings or trees around you which are causing unusual air flow then you can get specially shaped cowls which act like a wing and create a draw of air above the chimney.
    phillg's Avatar
    phillg is offline Looks like a 308 to me? -The Ferrari 288 GTO Club Member
    Nov 2006
    Dorset
    Phill Grimshaw
    2,641
    Quote Originally Posted by zoRob View Post
    I've had the bird problem,what a mess,another good reason to have some sort of cover on the chimney pot.
    Mar 2007
    kent
    spice
    1,861
    i have had two pidgeons and a parrot down mine, now got a closed in stove, very cosy and not as much mess
