Results 1 to 10 of 13
Thread: 348 water temperature
    May 2008
    Cascais
    Ricardo348spider
    72
    Question 348 water temperature
    I have ferrari 348 spider. In traffic and in 1st gera water temp rises to level seen in attachment pic. Is it normal/acceptable? once in 2nd and other gears it goes back to just below 90 degrees. I run straight pipes/decat
    Apr 2007
    Reading
    Gavin
    2,061
    I assume your fans cut in and it all returns to normal?
    Jun 2006
    South East UK / Hamburg
    Candellara
    6,309
    I would assume from this pic that the fans are not cutting in at all......and the temperature only comes back down when you're on the move again and the airflow increases.
    Definitely not normal for temps to be that high
    Iain
    7,173
    Quote Originally Posted by RacingSnake View Post
    +1 on that question. Like most cars it should run at 90 on the gauge pretty much regardless of what you do with it & whatever the weather.
    If it goes above but then falls back in the way that yours is then its usually fans not working.
    If it goes above and won't come back at all then either stuck thermostat, bad water pump or blocked rad (or just low coolant or an air lock)
    If it won't reach temperature (unless stuck in traffic) but then drops below when moving then its usually an old/weak spring in the thermostat.
    Mar 2007
    london
    P B B
    350
    In London traffic ( very slow ) mine rises to just below 90 before the fans come on and it drops back. I thought this was considered the normal range.
    May 2008
    Cascais
    Ricardo348spider
    72
    I realized that the metal cap that retains the coolant water is rusty. could this let pressure thru and cause temperature alterations?
    Jun 2006
    Candellara
    6,309
    Quote Originally Posted by ricbowling View Post
    Very unlikely, but i would replace this (its only about 17 IIRC) and replace your rad fan switch
    Angelis's Avatar
    London/Essex
    Sy
    17,035
    I used to have the same problem.
    Initially it was a faulty thermostat, but it didn't really get better until I had new radiators put in.
    May 2008
    Cascais
    Ricardo348spider
    72
    approximately how much for a pair of radiators?
    Aug 2006
    Worcestershire
    David
    116
    About 800 notes for the pair...........I think. Poss get them rebuilt?
  1. 348 water temperature
    By ricbowling in forum Technical Q & A
    Last Post: 09-10-2009, 06:18 PM
  2. Is the 348 a good Ferrari ?
  3. Water temperature for washing car?
    By Tim in forum Car Cleaning and Detailing
    Last Post: 05-06-2007, 10:39 AM
  4. 348 Water Pump quiz...
    By Gimme Fuel in forum Technical Q & A
    Last Post: 18-04-2007, 06:04 PM
