Results 1 to 10 of 17
Thread: 360 exhaust manifold
    Jan 2011
    bexley
    jon
    2
    Default 360 exhaust manifold
    hi guys, im looking for some help, been told that my exhaust manifold needs attention, after removing it and removing its heat shield its obvious that there is some cracks and also some distortion on the pipes, has anybody heard of this before or even had it happen to them?
    ive heard a few people say it happens on 355s but not so common on the 360???????
    does anybody know of anyone that can repair these manifolds or does it need replacing?
    many thanks
    Aug 2007
    Colchester
    355Chris
    666
    QV did the 355 ones; so I would try there. Never heard of it as a problem on 360.
    Jan 2011
    bexley
    jon
    2
    thanks chris, who are QV? where are they based? contact number? many thanks
    Jun 2008
    TW
    3,188
    Aug 2008
    kent
    Richard Dougal
    6
    Quote Originally Posted by squeakyjon View Post
    many thanks
    I have sent you a PM
    Jul 2009
    Aldous Voice
    3,589
    How many miles has your 360 done?
    Jul 2008
    London/Denmark
    Brian
    311
    Common problem. I've done both mine. 86,000 miles.
    Jan 2009
    Fixing someone's f-car
    Ed
    622
    They where never improved over the 355. I've changed/repaired loads...
    Isle Of Man
    360trev
    3,999
    When you start to investigate the manifolds you discover that this is a 15yr+ old problem that was never truely fixed...
    As a follow up to this. For both 360 and 430 owners the manifolds (just like on the F355) are a ticking time bomb and as the cars reach their old age they are showing up more as issues. There are options however, that is correct the problem in the first place. The new price from ferrari are just staggering, over 3 grand.
    The reason they crack in the first place appears to be because of the design. Incorrect thickness material used for the wall of the tubing that isn't matched correctly to the stresses they have to deal with in every day use. The main problem really is they should have fitted a bracket to help sustain the weight of the heavy cats (they weight 16kgs and the cats are suspended directly from the manifolds!!).
    Another option is to switch to much lighter sports cats which can be half as heavy. This dramatically reduces the stresses and loads on them so they tend not to crack then.
    Isle Of Man
    360trev
    3,999
    Thumbs up 360 Exhaust Manifolds
    Quote Originally Posted by ferraricyprus View Post
    As Eddie stated he's done loads of them and buying a set under duress always leads to much more expensive purchase. 3,000 for manifolds isn't much fun and the prices have gone up since the new year with the increased VAT rates.
    An alternative is to purchase sports manifolds from the US (Also called headers in American terminology!). The great thing about the non oem headers is the scope for improvement is substantial. The US ones I've seen can be nearly 7kg's lighter. Thats highly significant weight savings and as such I've just purchased a set. Fabspeed in the us sell them for $3,000 plus $400 for ceramic coating option [recommended];
    http://www.fabspeed.com/ferrari_360.html
    The other advantage is more torque and power. Apparently they add upto 25hp, well I'm sceptical of that claim and will dyno verify them, especially if you've already gained good power from free flowing exhaust and cats but I could easily see it adding 10hp if they've optimised the flow better than the stock system. They claim they've used Formula 1 Indy car high velocity merge collector which helps to smooth the cylinder gas pulses.
    We shall see. As a happy consequence of this latesst weight saving aquisition I have for sale a ridiculously low priced set of standard manifolds in perfect condition.
    I'm only looking for a fraction of the new price, first person to PM me with 495 gets them. This really is a bargin, I'll put an advert in the for sale section later alternatively just PM.
  1. New or used 360 exhaust
    By Darrell in forum Technical Q & A
    Last Post: 20-01-2011, 06:17 PM
  2. CS exhaust on a 360 spider
    By RedSpi in forum Technical Q & A
    Last Post: 13-03-2010, 08:22 PM
  3. Replies: 28
    Last Post: 09-03-2010, 06:30 PM
  4. 360 remote exhaust flap?
    By notax in forum Ferrari Talk
    Last Post: 13-12-2009, 03:23 PM
