Results 1 to 2 of 2
Thread: 348 HVAC Code E2.
    Mar 2013
    Matt
    1,173
    Default 348 HVAC Code E2.
    Hi,
    Had my HVAC panel off for de-stickying. Battery disconnected etc.
    Reinstalled it last night, powered up and I have code E2 - which according to a google is "Outside Air Temperature Sensor" , which according to another google is part 6 on here http://www.ricambiamerica.com/parts_...p?V=diag&I=294
    , though I havent been able to find a photo of it.
    Now, apart from opening the bonnet to switch on the battery, (and reinserting my horn relay - yay! mendored!) I havent been near front end for the duration of my de-stickying process, I hadnt even closed the bonnet at that stage , though have since. I've tried the IT man's trick of switch it off and switching on again (SIOASIOA) and that didnt work.
    (I could have believed getting an E1 - inside temp sensor because I've been near that with the drivers side vent grille etc)
    I was very careful removing the panel and plug , and only wiped it down whilst it was out with a semi-dry cotton bud lightly moistened with IPA to clean the "windows" and button edges.
    It was late when I got to that stage, so havent even looked for that sensor yet, but has anyone had the same issue before, please?
    Mar 2013
    Matt
    1,173
    Clock was flashing, just lucky enough to catch that on an "off".
  1. 348 E8 code
    By Yorkshirelad in forum Technical Q & A
    Last Post: 31-03-2018, 08:59 PM
  2. 355 HVAC Panel Overlay
    By Chris honeywell in forum Technical Q & A
    Last Post: 25-06-2013, 06:27 PM
  3. 348 ac fault code
    By rizlaneil1000 in forum Technical Q & A
    Last Post: 18-02-2009, 01:02 PM
  4. E8 poss E4 code on 348?
    By Doob in forum Technical Q & A
    Last Post: 15-02-2007, 10:53 PM
  5. 348 heater E8 code??
    Last Post: 17-07-2006, 11:47 AM
