Thread: 360 corroded wing mirror mounts
    Aug 2013
    Surrey
    178
    Default 360 corroded wing mirror mounts
    Anyone got an alternative to getting them taken off, refinished and respayed. Quite expensive process. Are there any reasonably priced aftermarket mounts eg in carbon fibre to stop the problem recurring? The wing mirrors themselves are fine.
    Thanks
    Chichester
    Simon
    61
    Mine are the same. If you find a solution, i would love to know about it...
    Titchfield
    Geoff T
    1,673
    Default 360 Mirror Mounts
    Did anyone provide a solution to the OP's question?
    Aug 2013
    Surrey
    178
    I ended up getting them refinished, but as part of a repaint of the front end which made it more cost effective
    Titchfield
    Geoff T
    1,673
    Quote Originally Posted by penman12012 View Post
    Did you remove them yourself? it seems that the tweeter and the panel inside the car just pull of and this exposes the 3 screws that hold the mirror and outer trim in place and that as long as you don't drop the screws then there's no need to remove the door card, is it this simple, also does anyone know what he correct black paint is.
    Aug 2013
    Surrey
    178
    Quote Originally Posted by geoffpfc View Post
    No I didn't. I expext there may be some wiring to the motor that moves the mirror to deal with as well.
    Oct 2015
    usk
    birdseye
    505
    The wiring is just a simple plug and socket but if memory serves, you cant get at the socket without removing the door card. That isnt so difficult - its re-installing it that is a PITA.
    As for the paint, Halfords Satin black was a match
  1. wing mirror badge
    By Roony in forum Ferrari Talk
    Last Post: 23-08-2008, 12:10 AM
  2. How to remove CS wing mirror
    By D8EAN in forum Technical Q & A
    Last Post: 21-04-2008, 01:49 PM
  3. Wobbly 360 wing mirror
    By Nikue in forum Technical Q & A
    Last Post: 20-04-2007, 10:05 AM
  4. Mysterious 360 Wing Mirror Nipple? What is it?
    By 360trev in forum Technical Q & A
    Last Post: 08-01-2007, 01:24 PM
  5. How to get a 360 wing mirror off
    By t1grm in forum Technical Q & A
    Last Post: 03-10-2006, 03:04 PM
