Results 1 to 9 of 9
Thread: Manual 360 gear shift issue (3rd gear crunch)
    May 2014
    Staffordshire
    Luke Sedzikowski
    4
    Default Manual 360 gear shift issue (3rd gear crunch)
    Hi,
    I am new to the forum and I have read up as much as I can but I can't see anyone with the same problem as me.
    I have a Manual 360 and have recently had a new clutch fitted. When I drive the car feels great but I can't get into 3rd gear. No matter what I do:
    (2nd-3rd change)
    (4th-3rd change)
    (2nd-Neutral-3rd change)
    (4th-Neutral-3rd change)
    When the car is parked I can get it into 3rd.
    The gear shifter surround hasn't been removed so I dont think it is an issue with alignment of that, any other suggestions? When the car went to the garage it didn't have any issues with going into gear.
    Thanks a lot
    Luke
    1,253
    Give vic a bell tomorrow at Migliore cars in bromsgrove 01527 576355
    Best gearbox man around
    He will point you in the right direction
    Dec 2009
    Slapshot
    513
    Broken 3rd gear synchro ring would be my guess.
    May 2014
    Staffordshire
    Luke Sedzikowski
    4
    Surly there would be a sign of the synchro failing?
    Dec 2009
    Slapshot
    513
    Quote Originally Posted by Luke_sedz View Post
    Well it's gear specific (3rd). Only a problem with the car moving. And not related to the gear shift linkage (another common problem) as you can engage 3rd easily enough while stationary.
    I hope someone else has a better suggestion otherwise the gearbox internals might need inspecting.
    May 2014
    Staffordshire
    Luke Sedzikowski
    4
    I've just filmed it whilst parked up.
    http://www.youtube.com/watch?v=K1yCD8Gxt94
    1,253
    Yeap
    Have you rang vic?
    West Midlands
    Richard
    77
    Default What he said....
    Quote Originally Posted by milkshaker0007 View Post
    Yeap
    Have you rang vic?
    ^^^ +1
    May 2014
    Staffordshire
    Luke Sedzikowski
    4
    I haven't rang him yet as I'm sure he doesn't want people calling him for advice. I will try and get to the bottom of it a bit more first.
    Is this classed as excess play in the shifter or is this normal?
    http://www.youtube.com/watch?v=8gE-Z-uGUaA
  1. 348 Broken gear shift lever.
    By Philip Barnard-Brown in forum Technical Q & A
    Last Post: 19-03-2011, 11:34 PM
  2. 360 Manual, optimum rpm gear shifts ...
    By Sidester in forum Ferrari Talk
    Last Post: 19-04-2010, 09:11 AM
  3. 360 Gear Change Question (manual)
    By SJF in forum Ferrari Talk
    Last Post: 20-11-2009, 08:24 AM
  4. 360 Manual clutch and gear change technique
    By SE16 in forum Ferrari Talk
    Last Post: 03-06-2007, 10:42 AM
