Results 1 to 10 of 13
Thread: 360 Modena light corrosion rectification
    Jun 2008
    TW
    3,188
    Default 360 Modena light corrosion rectification
    A 360 Modena that we supplied around 4 years ago, now suffering some minor corrosion. Time to reset the clock a little.
    Jun 2008
    TW
    3,188
    We now have access to an amazing spray booth for light works. It rolls from car to car from an overhead gantry - a superb system.
    Jun 2008
    TW
    3,188
    Repair in progress.
    Titchfield
    Geoff T
    1,673
    I look forward to seeing the finished result, it's great that you can blend in to quite a small area, do you use a special primer on the aluminium?
    Jun 2008
    TW
    3,188
    Hi Geoff we use very high quality paints to be able to do this.
    Finished.
    Jun 2008
    TW
    3,188
    Impact stickers fitted.
    Titchfield
    Geoff T
    1,673
    Lovelı work I have one very small spot of corrosion on an inner door cill, which I should be able to touch in with a small brush, I'll rub down the alloy, but do I need a special primer?
    many thanks
    760
    Nice work - I note you use a black primer / prep. Can you let us know what that is?
    Jun 2008
    TW
    3,188
    Hello Graham,
    Its the latest Ultra Violet paint tech. Its made by Sikkens, very expensive and you need all the UV equipment and lamps (the lamps alone are £12k each).
    We're very lucky to have access to this equipment.
    T.
    Titchfield
    Geoff T
    1,673
    Default Primer for Aluminium
    Does anyone have any recommendations, apart from Halfords, for primer/undercoat for touching up small area's of corrosion. ?
  1. F430 engine 'corrosion'
    By PurpleHaze in forum Ferrari Talk
    Last Post: 04-11-2012, 10:33 AM
  2. Corrosion Issue F 430
    By Akajak in forum Ferrari Talk
    Last Post: 29-10-2012, 10:42 AM
  3. 360 Modena F1 Light illuminating
    By chip360 in forum Technical Q & A
    Last Post: 01-01-2012, 08:33 PM
  4. 360 - Brakes Light Warning Light
    Last Post: 15-08-2008, 12:57 AM
  5. 575 Bonnet Corrosion
    By t1grm in forum Technical Q & A
    Last Post: 29-07-2008, 12:12 PM
